Go to main content
StorageTek Dual 8Gb FC Dual GbE HBA, ExpressModule, Emulex Installation Guide For HBA Models SG-XPCIEFCGBE-E8-Z, SG-PCIEFCGBE-E8-Z, SG-XPCIEFCGBE-E8-N, SG-PCIEFCGBE-E8-N and 7105393
Exit Print View
Updated: August 2018
Observing ESD and Handling Precautions
Caution
Caution  - Damage to the HBA can occur as the result of careless handling or electrostatic discharge (ESD). Always handle the HBA with care to avoid damage to electrostatic sensitive components.
To minimize the possibility of ESD-related damage, use both a workstation antistatic mat and an ESD wrist strap. You can get an ESD wrist strap from any reputable electronics store or from Sun as part number 250-1007. Observe the following precautions to avoid ESD-related problems:
  • Leave the HBA in its antistatic bag until you are ready to install it in the system.
  • Always use a properly fitted and grounded wrist strap or other suitable ESD protection when handling the HBA, and observe proper ESD grounding techniques.
  • Hold the HBA by the edge of the metal canister, not by the connectors.
  • Place the HBA on a properly grounded antistatic work surface pad when it is out of its protective antistatic bag.
