Go to main content
To Install the HBA
- Attach
an antistatic wrist strap (refer to Observing ESD and Handling Precautions).
- Refer to your system installation
or service manual to determine an appropriate ExpressModule slot
in which to install the HBA.
- Press down on the plastic tab
to release the ExpressModule latch and pull the lever out until
it is nearly perpendicular to the ExpressModule front panel.
- Insert the HBA into its slot,
being careful that the extension on the bottom of the lever does
not come into contact with the chassis sheet metal during insertion.
- When the HBA is inserted nearly
all the way into its slot, push the lever back into its fully closed
position, allowing the lever extension to insert the HBA fully into
place.
