cfgadm -al
If the HBA is properly installed and storage is connected properly, you will see output similar to the following example. In this example, one port of an HBA is connected through a fabric switch to two ports of a disk array.
Ap_Id Type Receptacle Occupant Condition
c1 fc-fabric connected configured unknown
c1::200600a0b816005e disk connected configured unknown
c1::200700a0b816005e disk connected configured unknown
c2 fc connected unconfigured unknown
pcie1 pci-pci/hp connected configured ok
