Bug 15593314
Issue: If you install the HBA in a Sun Blade X6250 system (32-bit) that uses the Oracle Solaris 10 01/13 OS, the Ethernet port mapping in the HBA will be incorrect, based on the listed order described in the Sun Blade X6250 system documentation.
Workaround: Verify the actual Ethernet port mapping for the HBA.
ifconfig e1000gdevice-instance-number plumb
This will help you identify whether the device is an HBA Ethernet port or any other Ethernet port.
ifconfig -a
The designator for the HBA Ethernet port has a MAC address of 00:00:C9:xx:xx:xx.
