This section provides information about selected platforms and storage that are compatible with the heterogeneous FC network design of the HBA. This section contains the following topics:
The HBA is supported by the platforms and operating systems listed in Figure 3, Table 3, Platform and Operating System Support.For up-to-date information, see your server Product Notes and web pages.
For supported operating system and technology versions, see Figure 2, Table 2, Supported Operating System/Technology Versions (Minimum) .
The system must have an available ExpressModule slot in which you can install the HBA.
This section lists the arrays and tape storage supported by the HBA. This section contains the following topics:
The HBA supports connecting to, using a supported switch, the following arrays:
StorageTek 2540
StorageTek 6140
StorageTek 6540
StorageTek 6780
StorageTek 9970
StorageTek 9980/9985
StorageTek 9990
The HBA supports connecting to, using a supported switch, the following tape storage:
StorageTek 9970 system
StorageTek 9980/9985/9985V system
StorageTek 9990/9900V system
StorageTek SL24 tape autoloader
StorageTek SL48 tape library
StorageTek L1400 tape library
StorageTek virtual tape library (VTL): VTL Value and VTL Plus
StorageTek SL500 modular library
StorageTek SL8500 modular library
StorageTek SL3000 modular library
IBM and HP LTO3 tape drives
IBM and HP LTO4 tape drives
StorageTek T10000A and T10000Btape drive
StorageTek T9840C tape drive
StorageTek T9840D tape drive
The HBA supports connecting to any 8 Gb/s Fibre Channel (FC) switch from any vendor that follows standard FC specifications, with the following considerations:
Direct Access Storage for FC is supported with COMSTAR.
The NIC portion of this adapter is supported by all 1-Gb Ethernet switches.
The HBA is supported by the software applications listed in Figure 4, Table 4, Software Support .
