Go to main content
oracle home
StorageTek Dual 8Gb FC Dual GbE HBA, ExpressModule, Emulex Installation Guide For HBA Models SG-XPCIEFCGBE-E8-Z, SG-PCIEFCGBE-E8-Z, SG-XPCIEFCGBE-E8-N, SG-PCIEFCGBE-E8-N and 7105393
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun StorageTek Dual 8Gb FC Dual GbE HBA, ...
Hardware Installation and Removal
Removing the Hardware
To Remove the HBA Hardware
Updated: August 2018
Document Information
Using This Documentation
Product Documentation Library
Feedback
Chapter 1 HBA Overview
Kit Contents
HBA Features and Specifications
Operating System and Technology Requirements
System Interoperability
Host Platform Support
Storage Support
Array Support
Tape Storage Support
Switch Support
Software Support
Boot Support
Environmental Requirements
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Best Practices for Installing the HBA
General Best Practices
Best Practices For Switches and Zoning
Best Practices For Booting From SAN (BFS) Configurations
Best Practices For Testing the Environment
Installing the Hardware
To Install the HBA
To Connect the Optical Cables
To Install the Ethernet Cables
To Apply Power
Testing the Installation
To Verify Proper Installation (Oracle Solaris)
To Verify Attached Storage (Oracle Solaris)
Configuring the HBA for Hot-Plug Operation
To Configure the HBA for Hot-Plug Operation
To Prepare the HBA for Removal Using the HBA Attention Button
To Prepare the HBA for Hot-Plug Removal (Oracle Solaris)
Chapter 3 HBA Software Installation
Installing Utilities for Updating the BIOS and Firmware
To Install Utilities for Updating the BIOS or Firmware:
Installing Diagnostic Software
Diagnostic Support for the Oracle Solaris OS
Diagnostic Support for All Other Supported Operating Systems
To Install Diagnostic Support Utilities for a Supported OS Other Than the Oracle Solaris OS:
Using the OneCommand Manager CLI for Troubleshooting a Fatal Error
About Automatic Firmware Dumps
Installing Drivers
Installing Drivers for the Oracle Solaris OS
Installing Drivers for All Other Supported Operating Systems
Chapter 4 Known Issues
Server Compatibility Issues
Cannot Detect the HBA on the Sun Blade T6300 System
Cannot Verify the FCode Version of the HBA on the Sun Blade T6300 and T6320 Systems
Cannot Boot-From-SAN on the Sun Blade X6250 System
To Modify the BIOS Menu
HBA Fails to Properly Disconnect During a Hot-Plug Operation on a Sun Blade T6320 System
HBA Does Not Correctly Map Ethernet Settings on a Sun Blade X6250 System
To Verify the Ethernet Port Mapping for the HBA
On the Sun Blade X6275 System, Default HBA Settings Do Not Allow Boot-From-SAN Through FC Ports
To Enable Boot-From-SAN Through the FC Ports of the HBA
Language:
English
Disconnect all cables.
Press the HBA latch to disengage the HBA.
Pull forward and down to eject the HBA from the system.
You can now remove the HBA.
Previous
Next
