man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
cmsg(3HEAD)
Name
socket.h, socket, cmsg - Internet Protocol family
Synopsis
#include <sys/socket.h>
Description
The sys/socket.h header defines the unsigned integral type sa_family_t through typedef.
The sys/socket.h header defines the sockaddr structure that includes the following members:
sa_family_t   sa_family     /* address family */
char          sa_data[]     /* socket   address (variable-length
                                data) */
libxnet Interfaces
The sys/socket.h header defines the msghdr structure for libxnet interfaces that includes the following members:
void            *msg_name         /* optional address */
socklen_t       msg_namelen       /* size of address */
struct iovec    *msg_iov          /* scatter/gather array */
int             msg_iovlen        /* members in msg_iov */
void            *msg_control      /* ancillary data, see below */
socklen_t       msg_controllen    /* ancillary data buffer len */
int             msg_flags         /* flags on received message */
The sys/socket.h header defines the cmsghdr structure for libxnet that includes the following members:
socklen_t  cmsg_len      /* data byte count, including hdr */
int        cmsg_level    /* originating protocol */
int        cmsg_type     /* protocol-specific type */
Ancillary data consists of a sequence of pairs, each consisting of a cmsghdr structure followed by a data array. The data array contains the ancillary data message, and the cmsghdr structure contains descriptive information that allows an application to correctly parse the data.
The values for cmsg_level will be legal values for the level argument to the getsockopt() and setsockopt() functions. The SCM_RIGHTS type is supported for level SOL_SOCKET.
Ancillary data is also possible at the socket level. The sys/socket.h header defines the following macros for use as the cmsg_type values when cmsg_level is SOL_SOCKET.
SCM_RIGHTS
Indicates that the data array contains the access rights to be sent or received.
SCM_UCRED
Indicates that the data array contains a ucred_t to be received. The ucred_t is the credential of the sending process at the time the message was sent. This is a Sun-specific, Committed interface. See ucred_get(3C).
The IPv4 data formats generally use the same values for data passed back in cmsghdr as for setsockopt() to enable the feature. The IPv4 data formats are listed below with the associated payload for each.
IPPROTO_IP
IP_RECVDSTADDR
ipaddr_t, IP address
IPPROTO_IP
IP_RECVOPTS
variable-length IP options, up to 40 bytes
IPPROTO_IP
IP_RECVIF
uint_t, ifIndex number
IPPROTO_IP
IP_RECVSLLA
struct sockaddr_dl, link layer address
IPPROTO_IP
IP_RECVTTL
uint8_t
SOL_SOCKET
SO_RECVUCRED
ucred_t — cmsghdr.cmsg_type is SCM_UCRED, not SO_RECVUCRED
The IPv6 data formats use different values for enabling the option and for passing the value back to the application. The IPv6 data formats are listed below with the associated payload for each.
IPPROTO_IPV6
IPV6_RECVPKTINFO
in_pktinfo, cmsg_type IPV6_PKTINFO
IPPROTO_IPV6
IPV6_RECVTCLASS
uint_t, cmsg_type IPV6_TCLASS
IPPROTO_IPV6
IPV6_RECVPATHMTU
ip6_mtuinfo, cmsg_type IPV6_PATHMTU
IPPROTO_IPV6
IPV6_RECVHOPLIMIT
uint_t, cmsg_type IPV6_HOPLIMIT
IPPROTO_IPV6
IPV6_RECVHOPOPTS
variable-length IPv6 options, cmsg_type IPV6_HOPOPTS
IPPROTO_IPV6
IPV6_RECVDSTOPTS
variable-length IPv6 options, cmsg_type IPV6_DSTOPTS
IPPROTO_IPV6
IPV6_RECVRTHDR
variable-length IPv6 options, cmsg_type IPV6_RTHDR
IPPROTO_IPV6
IPV6_RECVRTHDRDSTOPTS
The sys/socket.h header defines the following macros to gain access to the data arrays in the ancillary data associated with a message header:
CMSG_DATA(cmsg)
If the argument is a pointer to a cmsghdr structure, this macro returns an unsigned character pointer to the data array associated with the cmsghdr structure.
CMSG_NXTHDR(mhdr, cmsg)
If the first argument is a pointer to a msghdr structure and the second argument is a pointer to a cmsghdr structure in the ancillary data, pointed to by the msg_control field of that msghdr structure, this macro returns a pointer to the next cmsghdr structure, or a null pointer if this structure is the last cmsghdr in the ancillary data.
CMSG_FIRSTHDR(mhdr)
If the argument is a pointer to a msghdr structure, this macro returns a pointer to the first cmsghdr structure in the ancillary data associated with this msghdr structure, or a null pointer if there is no ancillary data associated with the msghdr structure.
CMSG_SPACE(len)
Given the length of an ancillary data object, CMSG_SPACE() returns the space required by the object and its cmsghdr structure, including any padding needed to satisfy alignment requirements. This macro can be used, for example, to allocate space dynamically for the ancillary data. This macro should not be used to initialize the cmsg_len member of a cmsghdr structure. Use the CMSG_LEN() macro instead.
CMSG_LEN(len)
Given the length of an ancillary data object, CMSG_LEN() returns the value to store in the cmsg_len member of the cmsghdr structure, taking into account any padding needed to satisfy alignment requirements.
The sys/socket.h header defines the linger structure that includes the following members:
int   l_onoff   /* indicates  whether  linger option is enabled */
int   l_linger  /* linger time, in seconds */
The sys/socket.h header defines the following macros:
SOCK_DGRAM
Datagram socket
SOCK_STREAM
Byte-stream socket
SOCK_SEQPACKET
Sequenced-packet socket
The sys/socket.h header defines the following macros for use as the level argument of setsockopt() and getsockopt().
SOL_SOCKET
Options to be accessed at the socket level, not the protocol level.
SOL_ROUTE
Options to be accessed at the routing socket level, not the protocol level.
The sys/socket.h header defines the following macros for use as the option_name argument of getsockopt() or setsockopt() calls:
SO_DEBUG
Debugging information is being recorded.
SO_ACCEPTCONN
Socket is accepting connections.
SO_BROADCAST
Transmission of broadcast messages is supported.
SO_REUSEADDR
Reuse of local addresses is supported.
SO_KEEPALIVE
Connections are kept alive with periodic messages.
SO_LINGER
Socket lingers on close.
SO_OOBINLINE
Out-of-band data is transmitted in line.
SO_SNDBUF
Send buffer size.
SO_RCVBUF
Receive buffer size.
SO_ERROR
Socket error status.
SO_TYPE
Socket type.
SO_RECVUCRED
Request the reception of user credential ancillary data. This is a Sun-specific, Committed interface. See ucred_get(3C).
SO_MAC_EXEMPT
Mandatory Access Control (MAC) exemption for unlabeled peers. This option is available only if the system is configured with Trusted Extensions.
SO_ALLZONES
Bypass zone boundaries (privileged).
The sys/socket.h header defines the following macros for use as the valid values for the msg_flags field in the msghdr structure, or the flags parameter in recvfrom(), recvmsg(), sendto(), or sendmsg() calls:
MSG_CTRUNC
Control data truncated.
MSG_EOR
Terminates a record (if supported by the protocol).
MSG_OOB
Out-of-band data.
MSG_PEEK
Leave received data in queue.
MSG_TRUNC
Normal data truncated.
MSG_WAITALL
Wait for complete message.
AF_UNIX
UNIX domain sockets
AF_INET
Internet domain sockets
SHUT_RD
Disables further receive operations.
SHUT_WR
Disables further send operations.
SHUT_RDWR
Disables further send and receive operations.
libsocket Interfaces
These libxnet interfaces are available to XPG4v2 standard-conforming applications. See standards (5) .
The sys/socket.h header defines the msghdr structure for libsocket interfaces that includes the following members:
int            msg_iovlen       /* # elements in msg_iov */
caddr_t        msg_accrights    /* access rights sent/received */
The msg_name and msg_namelen parameters specify the destination address when the socket is unconnected The msg_name can be specified as a NULL pointer if no names are desired or required. The msg_iov and msg_iovlen parameters describe the scatter-gather locations, as described in read(2). The msg_accrights parameter specifies the buffer in which access rights sent along with the message are received. The msg_accrightslen specifies the length of the buffer.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
accept(3SOCKET), accept(3XNET) , bind(3SOCKET), bind(3XNET) , connect(3SOCKET), connect (3XNET), getpeername(3SOCKET), getpeername(3XNET), getpeerucred(3C), getsockname(3SOCKET), getsockname(3XNET), getsockopt(3SOCKET), getsockopt(3XNET) , libsocket(3LIB), listen(3SOCKET), listen(3XNET), recv (3SOCKET), recv(3XNET), recvfrom (3SOCKET), recvfrom(3XNET), recvmsg(3SOCKET), recvmsg(3XNET), send(3SOCKET), send(3XNET), sendmsg(3SOCKET), sendmsg(3XNET), sendto(3SOCKET), sendto(3XNET), setsockopt(3SOCKET), setsockopt(3XNET) , shutdown(3SOCKET), shutdown (3XNET), socket(3SOCKET), socket (3XNET), socketpair(3SOCKET), socketpair(3XNET), ucred_get(3C), attributes(5), standards(5)
