man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
resource(3HEAD)
Name
resource.h, resource - definitions for resource operations
Synopsis
#include <sys/resource.h>
Description
The <sys/resource.h> header defines the symbolic constants listed below as possible values of the which argument of getpriority() and setpriority(). See getpriority(3C).
PRIO_PROCESS
identifies the who argument as a process ID
PRIO_PGRP
identifies the who argument as a process group ID
PRIO_USER
identifies the who argument as a user ID
The following type is defined through typedef:
rlim_t
unsigned integer type used for limit values
The following symbolic constants are defined:
RLIM_INFINITY
a value of rlim_t indicating no limit
RLIM_SAVED_MAX
a value of type rlim_t indicating an unrepresentable saved hard limit
RLIM_SAVED_CUR
a value of type rlim_t indicating an unrepresentable saved soft limit
The symbolic constants listed below are defined as possible values of the who parameter of getrusage(). See getrusage(3C) .
RUSAGE_SELF
returns information about the current process
RUSAGE_CHILDREN
returns information about children of the current process
The <sys/resource.h> header defines the rlimit structure, which includes the following members:
rlim_t rlim_cur     /* the current (soft) limit */
rlim_t rlim_max     /* the hard limit */
The <sys/resource.h> header defines the rusage structure, which includes the following members:
struct timeval ru_utime     /* user time used */
struct timeval ru_stime     /* system time used */
The timeval structure is defined as described in <sys/time.h>.
The symbolic constants listed below are defined as possible values for the resource argument of getrlimit() and setrlimit(). See getrlimit (2).
RLIMIT_CORE
limit on size of core dump file
RLIMIT_CPU
limit on CPU time per process
RLIMIT_DATA
limit on data segment size
RLIMIT_FSIZE
limit on file size
RLIMIT_NOFILE
limit on number of open files
RLIMIT_STACK
limit on stack size
RLIMIT_AS
limit on address space size
The id_t type is defined through typedef as described in <sys/types.h>. See types.h(3HEAD).
Inclusion of the <sys/resource.h> header can also make visible all symbols from <sys/time.h>. See time.h(3HEAD).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
getrlimit(2), getpriority(3C) , time.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
