man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
types32.h(3HEAD)
Name
types32.h, types32 - fixed-width data types
Synopsis
#include <sys/types32.h>
Description
The following fixed-width data types defined in <sys/types32.h> correspond to the sign and sizes of types in the 32-bit environment that can be used for compatibility and interoperability purposes in either the 32-bit or 64-bit environment.
typedef
int32_t
blkcnt32_t
typedef
uint32_t
caddr32_t
typedef
int32_t
clock32_t
typedef
int32_t
daddr32_t
typedef
uint32_t
dev32_t
typedef
uint32_t
fsblkcnt32_t
typedef
uint32_t
fsfilcnt32_t
typedef
int32_t
gid32_t
typedef
int32_t
id32_t
typedef
uint32_t
ino32_t
typedef
int32_t
key32_t
typedef
uint32_t
major32_t
typedef
uint32_t
minor32_t
typedef
uint32_t
mode32_t
typedef
uint32_t
nlink32_t
typedef
int32_t
pid32_t
typedef
uint32_t
rlim32_t
typedef
uint32_t
size32_t
typedef
int32_t
ssize32_t
typedef
time32_t
int32_t
typedef
uid32_t
int32_t
