man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
ftw(3HEAD)
Name
ftw.h, ftw - file tree traversal
Synopsis
#include <ftw.h>
Description
The <ftw.h> header defines the FTW structure that includes the following members:
int base
int level
The <ftw.h> header defines macros for use as values of the third argument to the application-supplied function that is passed as the second argument to ftw() and nftw() (see ftw(3C)):
FTW_F
file
FTW_D
directory
FTW_DNR
directory without read permission
FTW_DP
directory with subdirectories visited
FTW_NS
unknown type; stat() failed
FTW_SL
symbolic link
FTW_SLN
symbolic link that names a nonexistent file
The <ftw.h> header defines macros for use as values of the fourth argument to nftw():
FTW_PHYS
Physical walk, does not follow symbolic links. Otherwise, nftw() follows links but does not walk down any path that crosses itself.
FTW_MOUNT
The walk does not cross a mount point.
FTW_DEPTH
All subdirectories are visited before the directory itself.
FTW_CHDIR
The walk changes to each direct ory before reading it.
The <ftw.h> header defines the stat structure and the symbolic names for st_mode and the file type test macros as described in <sys/stat.h>.
Inclusion of the <ftw.h> header might also make visible all symbols from <sys/stat.h>.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
ftw(3C), stat.h(3HEAD), attributes(5), standards(5)
