man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
dirent(3HEAD)
Name
dirent.h, dirent - format of directory entries
Synopsis
#include <dirent.h>
Description
The internal format of directories is unspecified. The <dirent.h> header defines the following type:
DIR
A type representing a directory stream.
The header also defines the structure dirent, which includes the following members:
ino_t d_ino        /* file serial number */
char  d_name[]     /* name of entry */
The type ino_t is defined as described in <sys/types.h>. See types(3HEAD).
The character array d_name is of unspecified size, but the number of bytes preceding the terminating null byte must not exceed {NAME_MAX}.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
closedir(3C), opendir(3C), readdir(3C), rewinddir(3C), seekdir(3C), telldir(3C), types.h(3HEAD), attributes(5), standards(5)
