man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
glob.h(3HEAD)
Name
glob.h, glob - pathname pattern-matching types
Synopsis
#include <glob.h>
Description
The <glob.h> header defines the structures and symbolic constants used by the glob(3C).
The structure type glob_t contains the following members:
size_t gl_pathc       /* count of paths matched by pattern */
char   **gl_pathv     /* pointer to a list of matched
                         pathnames */
size_t gl_offs        /* lots to reserve at the beginning
                         of gl_pathv */
The following constants are provided as values for the flags argument:
GLOB_APPEND
Append generated pathnames to those previously obtained.
GLOB_DOOFFS
Specify how many null pointers to add to the beginning of gl_pathv.
GLOB_ERR
Cause glob() to return on error.
GLOB_MARK
Each pathname that is a directory that matches pattern has a slash appended.
GLOB_NOCHECK
If pattern does not match any pathname, then return a list consisting of only pattern.
GLOB_NOESCAPE
Disable backslash escaping.
GLOB_NOSORT
Do not sort the pathnames returned.
The following constants are defined as error return values:
GLOB_ABORTED
The scan was stopped because GLOB_ERR was set or (*errfunc)() returned non-zero.
GLOB_NOMATCH
The pattern does not match any existing pathname, and GLOB_NOCHECK was not set in flags.
GLOB_NOSPACE
An attempt to allocate memory failed.
GLOB_NOSYS
Reserved.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
glob(3C), attributes(5), standards(5)
