man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
siginfo.h(3HEAD)
Name
siginfo.h, siginfo - signal generation information
Synopsis
#include <siginfo.h>
Description
If a process is catching a signal, it might request information that tells why the system generated that signal. See sigaction(2). If a process is monitoring its children, it might receive information that tells why a child changed state. See waitid (2). In either case, the system returns the information in a structure of type siginfo_t , which includes the following information:
int            si_signo        /* signal number */
int            si_errno        /* error number */
int            si_code         /* signal code */
union sigval   si_value        /* signal value */
si_signo contains the system-generated signal number. For the waitid(2) function, si_signo is always SIGCHLD.
If si_errno is non-zero, it contains an error number associated with this signal, as defined in <errno.h> .
si_code contains a code identifying the cause of the signal.
If the value of the si_code member is SI_NOINFO, only the si_signo member of siginfo_t is meaningful, and the value of all other members is unspecified.
User Signals
If the value of si_code is less than or equal to 0, then the signal was generated by a user process (see kill (2), _lwp_kill(2) , sigqueue (3C), sigsend(2), abort(3C), and raise(3C) ) and the siginfo structure contains the following additional information:
pid_t        si_pid      /* sending process ID */
uid_t        si_uid      /* sending user ID */
ctid_t       si_ctid     /* sending contract ID */
zoneid_t     si_zoneid   /* sending zone ID */S
If the signal was generated by a user process, the following values are defined for si_code:
SI_USER
The implementation sets si_code to SI_USER if the signal was sent by kill (2), sigsend(2), raise(3C) or abort(3C).
SI_LWP
The signal was sent by _lwp_kill (2).
SI_QUEUE
The signal was sent by sigqueue (3C).
SI_TIMER
The signal was generated by the expiration of a timer created by timer_settime(3C) .
SI_ASYNCIO
The signal was generated by the completion of an asynchronous I/O request.
SI_MESGQ
The signal was generated by the arrival of a message on an empty message queue. See mq_notify (3C).
si_value contains the application specified value, which is passed to the application's signal-catching function at the time of the signal delivery if si_code is any of SI_QUEUE, SI_TIMER, SI_ASYNCHIO, or SI_MESGQ.
System Signals
Non-user generated signals can arise for a number of reasons. For all of these cases, si_code contains a positive value reflecting the reason why the system generated the signal:
Signal
Code
Reason
SIGILL
ILL_ILLOPC
illegal opcode
ILL_ILLOPN
illegal operand
ILL_ILLADR
illegal addressing mode
ILL_ILLTRP
illegal trap
ILL_PRVOPC
privileged opcode
ILL_PRVREG
privileged register
ILL_COPROC
co-processor error
ILL_BADSTK
internal stack error
SIGFPE
FPE_INTDIV
integer divide by zero
FPE_INTOVF
integer overflow
FPE_FLTDIV
floating point divide by zero
FPE_FLTOVF
floating point overflow
FPE_FLTUND
floating point underflow
FPE_FLTRES
floating point inexact result
FPE_FLTINV
invalid floating point operation
FPE_FLTSUB
subscript out of range
SIGSEGV
SEGV_MAPERR
address not mapped to object
SEGV_ACCERR
invalid permissions for mapped object
SIGBUS
BUS_ADRALN
invalid address alignment
BUS_ADRERR
non-existent physical address
BUS_OBJERR
object specific hardware error
BUS_MEM_UE
user process uncorrectable memory error
SIGTRAP
TRAP_BRKPT
process breakpoint
TRAP_TRACE
process trace trap
SIGCHLD
CLD_EXITED
child has exited
CLD_KILLED
child was killed
CLD_DUMPED
child terminated abnormally
CLD_TRAPPED
traced child has trapped
CLD_STOPPED
child has stopped
CLD_CONTINUED
stopped child had continued
SIGPOLL
POLL_IN
data input available
POLL_OUT
output buffers available
POLL_MSG
input message available
POLL_ERR
I/O error
POLL_PRI
high priority input available
POLL_HUP
device disconnected
Signals can also be generated from the resource control subsystem. Where these signals do not already possess kernel-level siginfo codes, the siginfo si_code will be filled with SI_RCTL to indicate a kernel-generated signal from an established resource control value.
Signal
Code
Reason
SIGXRES
SI_RCTL
resource–control generated signal
SIGHUP
SIGTERM
The uncatchable signals SIGSTOP and SIGKILL have undefined siginfo codes.
Signals sent with a siginfo code of SI_RCTL contain code-dependent information for kernel-generated signals:
Code
Field
Value
SI_RCTL
hr_time si_entity
process-model entity of control
In addition, the following signal-dependent information is available for kernel-generated signals:
Signal
Field
Value
SIGILL
caddr_t si_addr
address of faulting instruction
SIGFPE
SIGSEGV
caddr_t si_addr
address of faulting memory reference
SIGBUS
SIGCHLD
pid_t si_pid
child process ID
int si_status
exit value or signal
SIGPOLL
long si_band
band event for POLL_IN, POLL_OUT, or POLL_MSG
See also
_lwp_kill(2) , kill(2) , setrctl(2) , sigaction (2), sigsend(2), waitid(2), abort(3C), aio_read(3C), mq_notify(3C) , raise(3C) , signal.h(3HEAD), sigqueue(3C), timer_create(3C) , timer_settime (3C)
Notes
For SIGCHLD signals, if si_code is equal to CLD_EXITED, then si_status is equal to the exit value of the process; otherwise, it is equal to the signal that caused the process to change state. For some implementations, the exact value of si_addr might not be available; in that case, si_addr is guaranteed to be on the same page as the faulting instruction or memory reference.
