man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
msg.h(3HEAD)
Name
msg.h, msg - message queue structures
Synopsis
#include <sys/msg.h>
Description
The <sys/msg.h> header defines the following data types through typedef:
msgqnum_t
used for the number of messages in the message queue
msglen_t
used for the number of bytes allowed in the message queue
These types are unsigned integer types that are able to store values at least as large as a type unsigned short.
The <sys/msg.h> header defines the following constant as a message operation flag:
MSG_NOERROR
no error if big message
The msqid_ds structure contains the following members:
struct ipc_perm    msg_perm      Operation permission structure.
msgqnum_t          msg_qnum      Number of messages currently on
                                 queue.
msglen_t           msg_qbytes    Maximum number of bytes allowed
                                 on queue.
pid_t              msg_lspid     Process ID of last msgsnd(2).
pid_t              msg_lrpid     Process ID of last msgrcv(2).
time_t             msg_stime     Time of last msgsnd().
time_t             msg_rtime     Time of last msgrcv().
time_t             msg_ctime     Time of last change.
The pid_t, time_t, key_t, size_t, and ssize_t types are defined as described in <sys/types.h>. See types(3HEAD).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
msgctl(2), msgget(2), msgrcv(2), msgsnd(2), ipc.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
