#include <stdio.h>
The <stdio.h> header defines the following macros as positive integer constant expressions:
size of <stdio.h> buffers
input/output fully buffered
input/output line buffered
input/output unbuffered
maximum size of character array to hold ctermid() output
maximum size of character array to hold tmpnam() output
seek relative to current position
seek relative to end-of-file
seek relative to start-of-file
The following macros are defined as positive integer constant expressions that denote implementation limits:
Maximum size in bytes of the longest filename string that the implementation guarantees can be opened.
Number of streams that the implementation guarantees can be open simultaneously. The value is at least eight.
Minimum number of unique filenames generated by tmpnam(). Maximum number of times an application can call tmpnam() reliably. The value of {TMP_MAX} is at least 25. On XSI-conformant systems, the value of {TMP_MAX} is at least 10000.
The following macro name is defined as a negative integer constant expression:
end-of-file return value
The following macro name is defined as a null pointer constant:
null pointer
The following macro name is defined as a string constant:
default directory prefix for tempnam()
The following is defined as expressions of type “pointer to FILE” point to the FILE objects associated, respectively, with the standard error, input, and output streams:
standard error output stream
standard input stream
standard output stream
The following data types are defined through typedef:
structure containing information about a file
non-array type containing all information needed to specify uniquely every position within a file
as described in <stdarg.h>
as described in <stddef.h>
rename(2), ctermid(3C), fclose(3C), fdopen(3C), fflush(3C), fgetc(3C), fgetpos(3C), fgets(3C), flockfile(3C), fopen(3C), fputc(3C), fputs(3C), fputwc(3C), fread(3C), freopen(3C), fseek(3C), fsetpos(3C), ftell(3C), fwrite(3C), getwchar(3C), getopt(3C), perror(3C), popen(3C), printf(3C), remove(3C), rewind(3C), scanf(3C), setbuf(3C), stdio(3C), system(3C), tmpfile(3C), tmpnam(3C), ungetc(3C), vprintf(3C), attributes(5), standards(5)
