#include <stropts.h>
The <stropts.h> header defines the bandinfo structure, which includes the following members:
unsigned char bi_pri /* priority band */ int bi_flag /* flushing type */
The <stropts.h> header defines the strpeek structure that includes the following members:
struct strbuf ctlbuf /* control portion of the message */ struct strbuf databuf /* data portion of the message */ t_uscalar_t flags /* RS_HIPRI or 0 */
The <stropts.h> header defines the strbuf structure that includes the following members:
int maxlen /* maximum buffer length */ int len /* length of data */ char *buf /* pointer to buffer */
The <stropts.h> header defines the strfdinsert structure that includes the following members:
struct strbuf ctlbuf /* control portion of the message */ struct strbuf databuf /* data portion of the message */ t_uscalar_t flags /* RS_HIPRI or 0 */ int fildes /* file descriptor of the other stream */ int offset /* relative location of the stored value */
The <stropts.h> header defines the strioctl structure that includes the following members:
int ic_cmd /* ioctl() command */ int ic_timout /* timeout for response */ int ic_len /* length of data */ char *ic_dp /* pointer to buffer */
The <stropts.h> header defines the strrecvfd structure that includes the following members:
int fda /* received file descriptor */ uid_t uid /* UID of sender */ gid_t gid /* GID of sender */
The uid_t and gid_t types are defined through typedef as described in <sys/types.h>. See types.h(3HEAD).
The <stropts.h> header defines the t_scalar_t and t_uscalar_t types, respectively, as signed and unsigned opaque types of equal length of at least 32 bits.
The <stropts.h> header defines the str_list structure that includes the following members:
int sl_nmods /* number of STREAMS module names */ struct str_mlist *sl_modlist /* STREAMS module names */
The <stropts.h> header defines the str_mlist structure that includes the following member:
a STREAMS module name
The following macros are defined for use as the request argument to ioctl():
Push a STREAMS module.
Pop a STREAMS module.
Get the top module name.
Flush a stream.
Flush one band of a stream.
Ask for notification signals.
Retrieve current notification signals.
Look for a STREAMS module.
Peek at the top message on a stream.
Set the read mode.
Get the read mode.
Size the top message.
Send implementation-defined information about another stream.
Send a STREAMS ioctl().
Set the write mode.
Get the write mode.
Pass a file descriptor through a STREAMS pipe.
Get a file descriptor sent via I_SENDFD.
Get all the module names on a stream.
Is the top message ``marked''?
See if any messages exist in a band.
Get the band of the top message on a stream.
Is a band writable?
Set close time delay.
Get close time delay.
Connect two streams.
Disconnect two streams.
Persistently connect two streams.
Dismantle a persistent STREAMS link.
The following macro is defined for use with I_LOOK:
minimum size in bytes of the buffer referred to by the arg argument
The following macros are defined for use with I_FLUSH:
flush read queues
flush write queues
flush read and write queues
The following macros are defined for use with I_SETSIG:
A normal (priority band set to 0) message has arrived at the head of a stream head read queue.
A message with a non-zero priority band has arrived at the head of a stream head read queue.
A message, other than a high-priority message, has arrived at the head of a stream head read queue.
A high-priority message is present on a stream head read queue.
The write queue for normal data (priority band 0) just below the stream head is no longer full. This notifies the process that there is room on the queue for sending (or writing) normal data downstream.
Equivalent to S_OUTPUT.
The write queue for a non-zero priority band just below the stream head is no longer full.
A STREAMS signal message that contains the SIGPOLL signal reaches the front of the stream head read queue.
Notification of an error condition reaches the stream head.
Notification of a hangup reaches the stream head.
When used in conjunction with S_RDBAND, SIGURG is generated instead of SIGPOLL when a priority message reaches the front of the stream head read queue.
The following macro is defined for use with I_PEEK:
Only look for high-priority messages.
The following macros are defined for use with I_SRDOPT:
Byte-stream mode, the default.
Message-discard mode.
Message-non-discard mode.
Fail read() with [EBADMSG] if a message containing a control part is at the front of the stream head read queue.
Deliver the control part of a message as data when a process issues a read()
Discard the control part of a message, delivering any data part, when a process issues a read()
The following macro is defined for use with I_SWOPT:
Send a zero-length message downstream when a write() of 0 bytes occurs.
The following macros are defined for use with I_ATMARK:
Check if the message is marked.
Check if the message is the last one marked on the queue.
The following macro is defined for use with I_UNLINK:
Unlink all stream linked to the stream associated with fildes.
The following macros are defined for getmsg(), getpmsg(), putmsg(), and putpmsg():
Receive any message.
Receive message from specified band.
Send/receive high-priority message.
More control information is left in message.
More data is left in message.
The <stropts.h> header can make visible all of the symbols from <unistd.h>.
close(2), fcntl(2), getmsg(2), ioctl(2), open(2), pipe(2), poll(2), putmsg(2), read(2), write(2), signal(3C), types.h(3HEAD), unistd.h(3HEAD), attributes(5), standards( 5)
