man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
spawn.h(3HEAD)
Name
spawn.h, spawn - spawn
Synopsis
#include <spawn.h>
Description
The <spawn.h> header defines the posix_spawnattr_t and posix_spawn_file_actions_t types used in performing spawn operations.
The <spawn.h> header defines the flags that can be set in a posix_spawnattr_t object using the posix_spawnattr_setflags() function:
POSIX_SPAWN_RESETIDS
POSIX_SPAWN_SETPGROUP
POSIX_SPAWN_SETSCHEDPARAM
POSIX_SPAWN_SETSCHEDULER
POSIX_SPAWN_SETSIGDEF
POSIX_SPAWN_SETSIGMASK
Inclusion of the <spawn.h> header can make visible symbols defined in the <sched.h>, <signal.h>, and <sys/types.h> headers.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
sched.h(3HEAD), semaphore.h(3HEAD), signal.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
