man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
ndbm(3HEAD)
Name
ndbm.h, ndbm - definitions for ndbm database operations
Synopsis
#include <ndbm.h>
Description
The <ndbm.h> header defines the datum type as a structure that includes at least the following members:
void   *dptr     /* pointer to the application's data */
size_t dsize     /* size of the object pointed to by dptr */
The size_t type is defined through typedef as described in <stddef.h>.
The <ndbm.h> header defines the DBM type through typedef.
The following constants are defined as possible values for the store_mode argument to dbm_store():
DBM_INSERT
Insertion of new entries only.
DBM_REPLACE
Allow replacing existing entries.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
ndbm(3C), attributes(5), standards(5)
