Properties for filtering the server SP or CMM log entries are available in the CLI and web interface.
To filter log entries for the server SP or CMM, follow these steps:
For further details about filtering log entries shown in the web interface, click the More Details link on the log page.
For example:
show /System/Log/list Subsystem==subsystem
show /System/Log/list Type==type
show /SP|CMM/logs/event|audit/list Class==class
show /SP|CMM/logs/event|audit/list Class==class Type==type
show /SP|CMM/logs/event|audit/list Class==class Type==type Severity==value
Where:
subsystem is the subsystem component name, for example: System, Cooling, or Processor. For other examples, see the Subsystem examples listed in the Log Properties.
type is the event name or the component name where the event occurred, for example: OK, Warning, Service Required, Fann, Processorn, DCUn, DIMMn, UI, Product, Log, Update, or Action. For other examples, see the Component or Event Type examples listed in the Log Properties.
class is the class event name, for example: System, Fault, Chassis, Software, Audit, BIOS, or Sensor. For further information about the Class log property, see Class in the Log Properties.
severity is the event severity, for example: Debug, Down, Critical, Major, or Minor.
SP|CMM indicates a choice between the server SP or CMM. Type SP or CMM.
event|audit indicates a choice between the event and audit log. Type event to filter the event log, or type audit to filter the audit log.
