Host Diagnostic
Tasks and Applicable CLI Targets
Use the following table to help identify the applicable CLI
namespace targets for Oracle ILOM host diagnostic tasks.
For detailed information about host diagnostics, see the topics listed in the Related
Information section that appears after the table.
View or modify host diagnostic properties on an x86
server.
/HOST/diag state
enabled
disabled
extended
manual
set
Note -
To run and view diagnostics, launch the remote system
console from the web interface, and then restart the
server.
Note -
To issue the full CLI path for host diagnostics from the
CMM, append
/Servers/Blades/Blade_n
to the beginning of the /HOST/diag
target.
Note -
FMM, append
/Servers/ComputeNodes/ComputeNode_n
state target.
View or modify host diagnostic properties on a SPARC
server.
/HOST/diag
error_reset_level
error_reset_verbosity
hw_change_level
hw_change_verbosity
level
max
power_on_level
power_on_verbosity
trigger
verbosity
set
Note -
SPARC host diagnostic properties vary from system to
system. Use the Help command to
determine which host diag properties are supported on your
server. For example: help /HOST/diag
Note -
To issue the full CLI path for host diag from a
multi-domain SPARC server, append
/Servers/PDomains/PDomain_n
target.
Note -
system.
View or modify SP diagnostic properties on M7 or T7 series
SPARC servers.
/SP/diag
default_level
hw_change_level
Note -
To run and view diagnostics, launch the remote console
from the web interface, and then restart the system.
