Host Management Tasks and Applicable CLI Targets
Use the following table to help identify the applicable CLI targets for performing host
management tasks on a managed server.
For additional information about how to perform host management actions in Oracle ILOM, see
the topic listed in the Related Information section that appears after the
table.
Power on (start) or power off (stop) the server SP, CMM, or
FMM.
/System
Reset power on a server SP, CMM, or FMM.
/SP | CMM |
FMM
Turn on or turn off the system Locator LED from a server SP,
CMM, or FMM.
/System/locator_indicator
Set the boot device for the next host boot from an x86 server
SP.
/HOST/boot_device
Note -
To issue the full boot device path from the FMM CLI,
append
/Servers/ComputeNodes/ComputeNode_n
to the beginning of the
/HOST/boot_device target.
Manage the domain boot device from a SPARC server SP.
Set auto boot for both the host controller and guest domains
at startup.
Set boot guests to enable or disable guest domain booting at
startup.
/HOST/domain/
Note -
To issue the full CLI path for host domain on a
multi-domain SPARC server, append
/Servers/PDomains/PDomain_n
to the beginning of the /HOST target.
Set the host boot method properties on SPARC servers.
/HOST
autostart
autorunonerror
bootfailrecovery
bootrestart
bootimeout
maxbootfail
Note -
To issue the full CLI path for boot method on a
Set the trusted platform module (TPM) device on a SPARC
server.
/HOST/tpm
activate
enable
forceclear
mode
Note -
TPM properties vary from system to system. Use the
Help command to determine which
TPM properties are supported on your server. For example:
help /HOST/tpm
Note -
To issue the full CLI path for host TPM on a multi-domain
to the beginning of the /HOST/tpm
target.
