For targets where a change in properties can interrupt current user sessions, configuration includes committing the pending change to take affect.
For example, changing the IP network settings for the SP in Oracle ILOM will cause an interruption to the current user sessions. Therefore, you will be required to commit any changes you have made to the IP properties before your changes can take affect in Oracle ILOM.
An example of the process used to commit changes for IP properties appears below:
View the current network settings.
-> show /SP/network
/SP/network
Targets:
interconnect
ipv6
test
Properties:
commitpending = (Cannot show property)
dhcp_clientid = none
dhcp_server_ip = none
ipaddress = 192.0.2.22
ipdiscovery = static
ipgateway = 192.0.2.1
ipnetmask = 10.255.255.0
macaddress = 00:28:25:E7:18:0C
managementport = MGMT
outofbandmacaddress = 00:28:25:E7:18:0C
pendingipaddress = 192.0.2.22
pendingipdiscovery = static
pendingipgateway = 192.0.2.1
pendingipnetmask = 10.255.255.0
pendingmanagementport = MGMT
sidebandmacaddress = 00:28:25:E7:18:0D
state = enabled
Commands:
cd
set
show
To change the settings, first enter the new (pending) information.
->set /SP/network pendingipdiscovery=static pendingipaddress= nnn.nn.nn.nn pendingipgateway=nnn.nn.nn.nn pendingipnetmask=nnn.nn.nn.nn
Then, after you have confirmed that the new settings are correct, commit the new settings to have them take effect immediately:
-> set /SP/network commitpending=true
