Firmware Update Tasks and Applicable CLI Targets
Use the following table to help identify Oracle ILOM firmware
update tasks and CLI targets.
The following table does not provide the full CLI path to the
/SP target on all managed devices. For instance, to access
the /SP target from either a multi-domain SPARC server, a blade
system CMM, or a Netra FMM, append the applicable CLI properties to the beginning of
the /SP target:
SPARC multi-domain server, where applicable, append:
/Servers/PDomains/PDomain_n
Blade system CMM, where applicable, append:
/Servers/Blades/Blade_n
Netra frame system FMM, where applicable, append:
/Servers/ComputeNodes/ComputeNode_n
Note -
Not all firmware CLI targets are supported on all managed devices. Use the
help command to view the namespeace targets supported
on a managed device . For example,
help /SP/Firmware | help
/CMM/Firmware | help /FMM/Firmware
For detailed information about how to perform Oracle ILOM
firmware updates, see the topics listed in the Related Information
section that appears after the table.
View system BIOS properties or update system BIOS image (x86
only).
/System/BIOS
system_bios_version
boot_mode
Note -
To change the BIOS boot mode, refer to the
adminstration guide provided for the server.
reset_to_defaults
/Config load_uri
View the Oracle ILOM firmware version installed.
/System/Firmware
Update the SP, CMM, or FMM firmware image.
/SP|CMM|FMM/Firmware
load_uri
/host/miniroot
/keys
/backupimage
Note -
Not all firmware update properties listed in this table
are supported on all managed devices. To determine which
properties are supported, use the
help command (help
/SP|CMM|FMM/firmware)
Note -
SPARC server platforms require the host operating system
to be powered-off prior to performing the firmware
update.
View or update NEM firmware from the CMM.
/System/Firmware/Other_Firmware/
Note -
NEMs that do not support service processors will not be
listed under the firmware target.
View switch firmware version from FMM.
/System/Networking/Switches/Switch_n
Update blade chassis component firmware from the legacy CLI
target.
/CH/BLn/SP/NEMn
Note -
The host operating system on SPARC servers must be powered
off before performing a firwmare update.
