You can choose to execute commands to change target properties by performing any of the following methods:
Navigating to the target, looking at its properties, and executing a command.
For example, to set the HTTP user session time-out for the Oracle ILOM web server to 30 minutes, type:
-> cd /SP/services/http
/SP/services/http
-> show
/SP/services/http
Targets:
Properties:
port = 80
secureredirect = disabled
servicestate = enabled
sessiontimeout = 15
Commands:
cd
set
show
-> set sessiontimeout=30
Entering the command and the full path to the target, from anywhere in the namespace, and changing a single property.
For example:
-> set /SP/services/http sessiontimeout=30
Entering the command and the full path to the target, from anywhere in the namespace, and changing multiple properties.
For example:
-> set /SP/services/http servicestate=disable secureredirect=enabled
