Before You Begin
If the original component was configured as an ASR asset, then you must activate it after servicing or the replacement. An FMM, node, or switch can be configured as an ASR asset.
asr> activate_asset -i asset-IP-address asset
where asset-IP-address is the Oracle ILOM IP address of the asset and asset is the name of the asset: fmm, node, or switch.
