Remove or Install a Filler Panel
This task can take approximately 5 minutes to complete.
Filler panels are installed in empty slots only on the front of the modular system, to ensure that cooling is maximized within the system. If you remove a filler panel and install a component, save the filler panel. The rear of the modular system does not have filler panels.
Two types of filler panels are used. Solid filler panels cover empty node slots. Vented filler panels cover switches, empty switch slots, the FMM, and server support brackets.
Follow safety and ESD precautions.
See Safety and ESD Precautions.
Remove the filler panel by grasping it with a hand on left and right sides, then rock it a little while pulling it toward you.
The filler panels are held on by mounting brackets. Two types of mounting
brackets hold the panels on. Empty node slots and the FMM have one type of
mounting brackets. All other components use another type.
The filler panels over switch locations have a removable metal baffle attached to them.
Perform one of the following steps to remove the mounting bracket:
If you removed a filler panel for an empty
node slot or the FMM, use a No. 1 Phillips screwdriver to remove the
screws holding the bracket to the rails on both
sides.
To remove the other type of mounting bracket,
use a No. 3 Phillips screwdriver to loosen (not remove) the two
screws holding the bracket to both sides, then remove the bracket
only.
Save the filler panels, screws, and mounting brackets for use later.
Install a filler panel and mounting brackets.
For an empty node or the FMM slot:
Use a No. 1 Phillips screwdriver to insert the screws into the mounting brackets to the rails on both sides to reinstall them.
Place the filler panel on the front slot to be covered, then press it onto the mounting bracket until the filler panel snaps into place.
For other component slots:
Insert the mounting brackets under the loosened screws.
Use a No. 3 Phillips screwdriver to tighten the four screws onto the mounting brackets.
