Follow safety and ESD precautions.
See Safety and ESD Precautions.
Attach the cable protector (saved from faulty panel) to the replacement LED panel.
Connect the DB-9 LED cable to the replacement LED panel.
See Precautions for Handling Cords and Cables.
Check the functioning of the LED panel to ensure that the replacement LED
panel is operating.
Insert the LED panel into the slot, being careful not to crimp or damage
the cable.
When the LED panel is seated properly, insert the four screws and tighten
them.
Affix the applicable label onto the LED panel.
The replacement comes with two labels, one for the Netra Modular System
commercial use and another for CGBU Oracle Virtual Network Platform
use.
