Avant de commencer
Lors de l'enregistrement d'ASR Manager, saisissez vos informations de connexion MOS et les serveurs proxy, le cas échéant.
# asr register
1) transport.oracle.com
Votre sortie d'écran doit ressembler à ceci :
Proxy server name: ? <proxy server name> Proxy port number: ? <proxy port number> Proxy authentication; if authentication is not required, enter -. Proxy user: <proxy user name> Proxy password: <proxy password> If this is an NTLM type proxy, enter the information below. Otherwise, enter - NTLM Domain: [?] <NTLM domain name> Enter the host the NTLM authentication request is originating from. Usually this is the hostname of the SASM server. NTLM Host: [?] <NTLM host name> NTLM support is not bundled with SASM but may be added now. 1) Download jCIFS from http://jcifs.samba.org/ 2) Extract contents and locate the jcifs-*.jar file 3) Enter full path to this file below jCIFS jar file: [?] <full path of jCIFS jar file> Note: These properties are stored in the /var/opt/SUNWsasm/configuration/config.ini file. You can update these properties if needed and then restart SASM.
Votre adresse e-mail MOS reçoit une sortie de notification de problèmes ASR et de génération de demandes d'assistance.
