Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Changes the current target.
cd [-default] target
where target is the target and path to act upon.
This Oracle ILOM command changes the Oracle ILOM attention to the specified target. This command is similar to the change directory (cd) command of many operating systems.The -default option returns the attention to the default target.
This example shows how to change to the /SP/logs/event/list target with the cd command.
Note - The output in the example is a portion of the full output.
-> cd /SP/logs/event/list /SP/logs/event/list -> show /SP/logs/event/list Targets: Properties: Commands: cd s how ID Date/Time Class Type Severity ----- ------------------------ -------- -------- -------- 75 Wed Oct 7 20:12:31 2009 Audit Log minor root : Open Session : object = /session/type : value = shell : success 74 Wed Oct 7 20:12:28 2009 Audit Log minor root : Close Session : object = /session/type : value = shell : success 73 Wed Oct 7 20:11:21 2009 Audit Log minor root : Open Session : object = /session/type : value = shell : success . . . ->
