| Skip Navigation Links | |
| Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Sets the Subnet Manager priority.
setsmpriority priority|list
where priority is a number from 0 (lowest) to 13 (highest).
This hardware command sets the priority of the Subnet Manager within the management controller. You use this command when there are multiple Subnet Managers in the InfiniBand fabric. By setting a Subnet Manager to a higher priority than the other Subnet Managers, it becomes the or master Subnet Manager. When you set a Subnet Manager to a priority lower than the master Subnet Manager, it becomes a standby Subnet Manager. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, and subnet prefix.
The setsmpriority command writes the value of priority to the sm_priority parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsmpriority command. See disablesm Command.
Note - Setting Subnet Managers of the same fabric to the same priority can have undesirable results.
The setsmpriority command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the priority of the Subnet Manager to 5 using the setsmpriority command.
FabMan@switch_name->setsmpriority 5 Current SM settings: smpriority 5 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine FatTree FabMan@switch_name->
This example shows how to display the current settings of the Subnet Manager priority, controlled handover, subnet prefix, M_Key value, and routing algorithm with the list argument of the setsmpriority command.
FabMan@switch_name->setsmpriority list smpriority 0 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine FatTree FabMan@switch_name->
