Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays available RAM and filesystem space.
showfree [-m][-d][-k]
This hardware command displays the free RAM memory available for use by the management controller and the free disk space in the filesystem in megabytes. The available RAM is described as an absolute number of bytes and as a percentage of total. The available disk space is described as the filesystem, the mount point, the absolute number of bytes, and as a percentage of total.
The showfree command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the showfree command and their purposes.
This example shows how to display the available RAM and disk space in megabytes with the showfree command.
FabMan@switch_name->showfree -md Memory: 463.7 MB 93.1% Filesystems: /dev/hda2 / 197.3 MB 41.9% tmpfs /dev/shm 249.1 MB 100.0% tmpfs /tmp 248.2 MB 99.6% FabMan@switch_name->
Switch Administration, displaying free memory
