Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays host nodes.
ibhosts [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script that discovers the InfiniBand fabric topology or uses the existing topology file to extract the channel adapter nodes.
The ibhosts command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibhosts command and their purposes.
This example shows how to display the host node GUIDs with the ibhosts command.
Note - The output in the example is a portion of the full output and varies for each InfiniBand topology.
FabMan@switch_name->ibhosts Ca : 0x00212856cd22c000 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 0" Ca : 0x00212856cd22c040 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 1" Ca : 0x0002c903000891aa ports 2 "mnm34-54 HCA-1" Ca : 0x00212800013ece9e ports 2 "mnm34-55 HCA-1" Ca : 0x0003ba000100e370 ports 2 "mnm34-60 HCA-1" . . . FabMan@switch_name->
ibhosts man page
