Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays version information.
version
This Oracle ILOM command displays the version information within the management controller of the Sun Datacenter InfiniBand Switch 36 from Oracle.
This example shows how to display the version information with the version command.
-> version SP firmware 2.1.2-1 SP firmware build number: 47111 SP firmware date: Mon Oct 1 12:07:21 IST 2012 SP filesystem version: 0.1.22 ->
Switch Reference, version command
