Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays port counters.
getportcounters port|connector [-R]
where:
port is the number of the port (1 to 36).
connector is the name of the connector (0A to 17A and 0B to 17B).
This hardware command returns the error and data throughput counters of the specified port of the switch chip or connector of the switch. If a port is specified, then the output is for InfiniBand counters. Similarly, if the connector specified is 0A to 17B, the output is also for InfiniBand counters.
The -R option clears the counters for the specified port or connector.
The getportcounters command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the status of connector 1A with the getportcounters command.
FabMan@switch_name->getportcounters 1A Port counters for connector 1A Switch port 22 SymbolErrors.....................0 LinkRecovers.....................0 LinkDowned.......................0 RcvErrors........................0 RcvRemotePhysErrors..............0 RcvSwRelayErrors.................0 XmtDiscards......................0 XmtConstraintErrors..............0 RcvConstraintErrors..............0 LinkIntegrityErrors..............0 ExcBufOverrunErrors..............0 VL15Dropped......................0 XmtData..........................909556 RcvData..........................737760 XmtPkts..........................12830 RcvPkts..........................10368 XmtWait..........................0 FabMan@switch_name->
