Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Creates an IP over InfiniBand interface.
create_ipoib [-s][-n if_name][-m mask][-t if_type] p_key IP_address [-h]
where:
if_name is the identifier of the IP interface.
mask is the subnet mask.
if_type is the type of interface (external, internal, or both).
p_key is the partition key (1 to 7fff or default).
IP_address is the IP address of the interface.
This hardware command creates an IP interface, assigns it an IP address, and attaches it to a P_Key value for use over the InfiniBand fabric.
Note - IP interfaces created with the create_ipoib command are independent of those implemented through the fdconfig command.
This table describes the output of the create_ipoib -s command when IP over InfiniBand interfaces have been configured.
The create_ipoib command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the create_ipoib command and their purposes.
This example shows how to create an IP over InfiniBand interface with P_Key 0x0001 and IP address 123.45.67.89 with the create_ipoib command.
FabMan@switch_name->create_ipoib -n newipoib -m 255.255.254.0 -t both 0x0001 123.45.67.89 Create interface: Name PKey IP-address Subnetmask Interface Interface-type --------------------------------------------------------------------------- newipoib 0x0001 123.45.67.89 255.255.254.0 ib0 both FabMan@switch_name->
Switch Administration, creating the IPoIB interface
