| Skip Navigation Links | |
| Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays help for a command.
help command | class
where:
command is the command for which you need help.
class is the category of commands.
This hardware command provides help information for supported commands. Typically, the same information is provided using the -h option.
The help command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to get help with the help command.
FabMan@switch_name->help List of avaliable classes: general -- General commands diag -- Switch diagnostics commands ibdiag -- Infiniband diagnostics commands sm -- Subnet Managager administration commands other -- Other managagement commands all -- Show all commands Type "help" followed by a class name for a list of commands in that class. Type "help" followed by a command name for description and usage of the command. FabMan@switch_name->
Switch Remote Management, help command
