Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays power supply FRU ID information.
showpsufru slot
where slot is the power supply slot (0 or 1).
This hardware command displays FRU ID information for the power supplies.
The showpsufru command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the FRU ID information for power supply 0 with the showpsufru command.
FabMan@switch_name->showpsufru 0 Sun_SpecPartNo : 885-1165-02 UNIX_Timestamp32 : Sun Jan 3 15:35:39 2010 Sun_Part_Number : 3002143 Sun_Serial_No : BF15WA Vendor_ID_Code : 02a2 Initial_HW_Dash_Level : 02 PSU_Voltage 1 : 0x04b0 (1200) PSU_Current 1 : 0x186a (6250) PSU_Voltage 2 : 0x014a (330) PSU_Current 2 : 0x012c (300) Sun_Hazard_Class_Code : Y IPMI_Board_Manufacturer : EMERSON IPMI_Board_Product_Name : A237 IPMI_Board_Serial_Number: 1357ZHO-0952BF15WA IPMI_Board_Part_Number : 300-2143-02 FabMan@switch_name->
