Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Displaying Information About Nodes
Identify All Switches in the Fabric
Identify All CAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Displaying Fabric Functionality Configuration Information
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Display the Fabric Element Configuration
Display Configured Secret M_Keys
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Disable or Enable an External Port
Partitioning the InfiniBand Fabric
smpartition Command Guidelines
Determine the Partitions and P_Keys
Add or Remove a Port From a Partition
Remove User Partitions for Firmware Downgrade
Create a Fabric Element Configuration
Add or Delete an Element From the Configuration
Modify an Element of the Configuration
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
