Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Sets persistence of the M_Key.
localmkeypersistence enable|disable|show|help
This hardware command sets the persistence of the M_Key used by the I4 switch chips to survive a reboot of the management controller. The command has four arguments:
enable – After a reboot, the local M_Key is restored before enabling the I4 switch chip ports.
disable – After a reboot, the previous local M_Key is lost and no local M_Key is set before the Subnet Manager becomes operational.
show – Displays the local M_Key persistence status.
help – Provides help.
The localmkeypersistence command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to display the local M_Key persistence status with the localmkeypersistence command.
FabMan@switch_name->localmkeypersistence show Local M_Key persistence is enabled. Local M_Key will be restored after reboot before switch ports are enabled. FabMan@switch_name->
Switch Administration, enabling secret M_Key persistence
