Attach the CMA to the Server
Before attaching the CMA to the server, ensure that the correct cable covers are installed on the CMA.
Prepare the CMA for installation on the server.
See Prepare the CMA for Installation.
To make it easier to install the CMA, extend the server approximately 13 cm (5 inches) out of
the front of the rack.
Take the CMA to the back of the equipment rack, and ensure that you have adequate room to work
at the back of the server.
Note -
References to “left” or “right” in this procedure assume that you are
facing the back of the equipment rack.
Note -
Throughout this installation procedure, support the CMA and do not allow it to hang under its
own weight until it is secured at all four attachment points.
Install the CMA's connector A into the left slide rail.
Insert the CMA's connector A into the front slot on the left slide rail until it locks into
place with an audible click (panels 1 and 2).
The connector A tab goes into the slide rail's front slot (panel 1).
1
Connector A tab
2
Left slide rail front slot
Gently tug on the right side of the front slide bar to verify that connector A is properly
seated.
Install the CMA's connector B into the right slide rail.
Insert the CMA's connector B into the front slot on the right slide rail until it locks into
The connector B tab goes into the slide rail's front slot (panel 1).
Gently tug on the right side of the front slide bar to verify that connector B is properly
seated.
1
Connector B tab
2
Right slide rail front slot
Install the CMA's connector C into the right slide rail.
Align connector C with the slide rail so that the locking spring (callout 1) is positioned
inside (server side) of the right slide rail (panel 1).
1
Connector C locking spring
Insert connector C into the right slide rail until it locks into place with an audible click
(panels 2 and 3).
Gently tug on the right side of the CMA's rear slide bar to verify that connector C is
properly seated.
Prepare the CMA's connector D for installation.
Remove the tape that secures the slide rail
latching bracket to connector D and ensure that the latching bracket is properly aligned with
connector D (panels 1 and 2).
Note -
The CMA is shipped with the slide rail latching bracket taped to connector D. You must remove the tape before you install this connector.
Install the CMA's connector D into the left slide rail.
While holding the slide rail latching bracket in place, insert connector D and its associated
slide rail latching bracket into the left slide rail until connector D locks into place with an
Note -
When inserting connector D into the slide rail, the preferred and easier method is to install
connector D and the latching bracket as one assembly into the slide rail.
Gently tug on the left side of the CMA's slide bar to verify that connector D is properly
seated.
Note -
The slide rail latching bracket has a green release tab. This tab is used to release and
remove the latching bracket so that you can remove connector D.
seated.
Note -
Gently tug on the four CMA connection points to ensure that the CMA connectors are fully
seated before you allow the CMA to hang by its own weight.
Verify that the slide rails and CMA operate properly.
See Verify Operation of Slide Rails and CMA.
