Server Overview
This topic provides a high-level introduction to the main
components and capabilities of the server.
Chassis |
Rack-mountable server. |
CPU |
One M8 processor installed on the motherboard assembly. |
Memory |
Eight DDR4 DIMMs connect to the motherboard. An additional eight DIMMs can connect to two
memory risers (optional). A server with 16 64-GB DIMMs supports 1024
GB of system memory.
I/O expansion |
Six PCIe Gen3 slots. All slots support x8 PCIe cards. A two x16 and two x8 PCIe card
configuration is also suported. |
Storage devices |
Eight 2.5-inch drive bays, accessible through the front
panel.
USB ports |
Video port |
One high-density DB-15 video port (rear) |
Ethernet ports |
Four 10GbE 100 Mbps/1 Gbps/10 Gbps, RJ-45-based ports on the rear panel. |
Power supplies |
Two hot-swappable (1+1) AC 1200W power supplies. |
Cooling fans |
Four hot-swappable, redundant fan modules at mid-chassis (top-loading). Redundant fans in each
power supply. |
SP |
Oracle Integrated Lights Out Manager
(Oracle ILOM). |
