Creating and Modifying Expense Reports Using PeopleSoft Fluid
Using PeopleSoft Fluid, you can create expense reports in two ways:
In addition to the pages listed in the table below, these topics are discussed:
Pages Used to Create and Modify Expense Reports using PeopleSoft Fluid
Expense Report Page
EX_SHEET_HDR_FL
Enter the General Information of the expense report.
My Expense Reports Page
EX_EXP_LIST_FL
Review all of your expenses in various statuses.
Expense Details Page
EX_SHEET_DTL_FL
Add a new expense entry or import from My Wallet.
Expense Entry Page
EX_SHEET_LN_FL
Enter expense information.
Expense Report Summary Page
EX_SHEET_SUM_FL
View the total summary of the expense report and allow user to submit the expense report.
Expense Report Page
Use the Expense Report page (EX_SHEET_HDR_FL) to enter the General Information of the expense report.
Navigation:
Employee Self Service, and then Expenses tile, and then Create Expense Report tile
This example illustrates the fields and controls on the Expense Report page.
Expense Report page
You can create a new expense report or import expense data from your wallet.
Complete the information in the General Information section first. The Business Purpose, Description and Default Location fields are automatically populated based on your user profile set up. PeopleSoft Fluid Expenses populates most of these fields with information that you set up on the Employee Privilege Template Page. You can change this information if needed.
Select an option in the Expense Report Action field. The system automatically takes you to the desired page.
Field or Control Description
Actions
Select to:
  • Change Employee - takes you to an employee search page where you can change the employee if you are a delegate or proxy user.
  • User Defaults - to access the Employee Profile - User Defaults Page where you can view or update your defaults. This option is available only on devices such as desktops and laptops.
Business Purpose
Select a business purpose from the list. If your user profile is setup with default Business Purpose, the information will automatically be populated in this field.
Description
Enter a description to identify the expense report. If your user profile is setup with default Business Purpose, the information will automatically be populated in this field.
Default Location
Enter a city, country, or geographical area where the expenses were generally incurred. This location will be applied on each expense entry where applicable, and you can change it throughout the expense report process. If you change the default location, PeopleSoft Expenses applies the new location to newly added expenses; the change does not affect existing expense lines
Note: If VAT is enabled, you must enter a default location so that PeopleSoft Expenses can determine the VAT treatment.
Reference
Select a reference id that has been predefined on the Reference Page. This field is used for tracking or identification
Attach Receipt
Add expense report receipt as attachment.
You can upload multiple files at a time depending on configured attachment upload limit. To configure attachment upload limit, see Application Fundamentals: Installation Options - Multiple Attachments Page.
After the attachment is uploaded, you can review the attachment by selecting either the Image preview icon or by image file name.
For more information, see Attachments Page (Expense Header Desktop)
Note: This section is available only when the following options are selected in the Receipts Confirmation group box on the Installation Options - Expenses Page: The Option field is Attachments Only or both, Image and Attachment. The Attachment Location field is Header Level or Header and Line.
Accounting Defaults
Select to access the Expense Report Defaults Page where you can establish default ChartField values for your expense report.
Because these defaults are established at the header level, all transactions on this expense report are charged to this department, fund, project, and activity combination, unless overridden at the line level.
For more information, see Viewing and Updating Expense Report Accounting using PeopleSoft Fluid
Note: This option is not available if the Default Accounting option on the Employee Privilege Template Page for the expense report transaction is set to Hide.
Select one of these options, if available. Available options depend on system configuration:
  • Add Expense Lines: select to add a new expense item manually and access the Expense Entry Page.
  • Add from My Wallet: select to access the My Wallet Page where you can import expenses into the expense report.
  • Add from Quick Fill: select to access the Quick Fill Page and select which expense types you want to add to the expense report.
  • Add from Template: select to access the Populate from Template Page window where you can select a pre-defined user or public template.
  • Copy Expense Report: select to access the Copy Expense Report Options Page.
Use the My Expense Reports page (EX_EXP_LIST_FL) to review all of your expenses in various statuses.
This example illustrates the fields and controls on the My Expense Reports page.
My Expense Reports
The data displays in a two-panel format. The left panel displays the expense report categories and the report-count for each category.
The right panel displays the expense reports based on the expense category you select on the left panel. The number bubble next to each status indicates the number of expense report in that status. The status that is highlighted in green is the status that is currently being selected.
On the right panel, select an expense report and drill down to My Expense Reports page. From this page, you can easily find the status of your expense report and who is the next in line to approve your report.
Select to create a new expense report. For more information, see Expense Report Page
Filter
Narrow down the expense report list. This Filter button will be displayed in green to indicate there is filter criteria being entered.
SortSort order
Sort the data within My Expense Reports list. The Sort button is displayed in green to indicate specific sort criteria that is being used.
Select icon
Select an expense report to view or update the expense report. If the expense report selected is not submitted yet, the system will display the Expense Detail page. Otherwise, the system will display the Report Summary page.
Left Panel icon
Select the slider to show the left panel of My Expense Reports.
On devices such as a tablet or a desktop, you may view the pages in the two-panel layout. The list of the expense reports are displayed in the grid format.
This example illustrates the fields and controls on the My Expense Reports page. You can find definitions for the fields and controls later on this page.
My Expense Report grid
This example illustrates the fields and controls on the My Expense Reports - Expense Entry page. You can find definitions for the fields and controls later on this page.
The data display on the left panel may different based on the Expense Report status. For example, the Approver Role and Approver Name are available on the expense report list in Awaiting Approval status. The type of device and the available screen space will also derive the information being displayed. For example, on smartphone, report Description and Business Purpose will not be displayed.
The following options are available to you when you view the My Expense Reports.
Copy To New Report
Copy the existing report to a new expense report.
Delete Report
Delete an Expense Report that is in pending status. This button is available only if the expense report status is Not Submitted or Returned by Approver.
Send Notification
Select to access the Send Email Page to send a notification to the approver or other people.
Download to Excel Search Results
Select to download the search results to Microsoft Excel spreadsheet.
Find Search Results
Select to find a string in the current page.
Sort Search Results
Select to sort the data within the Search Results grid.
Expense Reports Details
Select to view the Expense Entry page to review the entries and change summary.
Display Review Change Summary in Modal Window
Select to review the change summary.
Use the Expense Details page (EX_SHEET_DTL_FL to add a new expense entry or import from My Wallet.
Navigation:
Smart phone: Employee Self Service, and then Expenses tile, and then Create Expense Report tile. Select the Create Expense Report button.
Tablet: Employee Self Service, and then Expenses tile, and then Create Expense Report tile
From the Expense Report page, select the Create Expense Report button at the end of the page. Select Add Expense Lines from the Expense Report Action field.
This example illustrates the fields and controls on the Expense Details page.
Expense Details (SFF)
The grid on the Expense Details page display any expense entries created for the expense reports. General information about the expense report displays on the Header. The Total amount and Number of Items display the sum of the expenses amount in employee’s base currency and the number of expense items included in the expense report.
You can view or update user defaults by selecting User Defaults from the Action menu in the Expense Details header. The User Defaults option is available only on devices such as desktops and laptops. For more information, see Maintaining User Defaults
The Expense Details page has the following action buttons:
General Information icon (general information)
Select to return to the Expense Report Page where you can change header information.
<User name> Related Actions
Select to access actions such as User Defaults, which takes you to the Employee Profile - User Defaults Page.
Add Expense (add)
Select to add a new expense line. See Expense Entry Page
Import from Wallet (wallet)
Select to access the My Wallet Page and import transcations.
Attach (attach)
Attach receipts for an expense entry.
Depending on configured attachment upload limit, you can upload multiple files at a time for one expense item. To configure attachment upload limit, see Application Fundamentals: Installation Options - Multiple Attachments Page.
The Attach button turns green which indicates that you are in the attachment mode for uploading receipt file. Select the wallet entry on which you want to add the receipt image. To return to normal mode, select the Attach button again.
For more information, see Attachments Page (Expense Line Smartphone)
Delete (delete)
Delete an expense entry that was entered or imported from wallet.
On mobile device such as smartphone, the Attach button turns green that indicates that you are in the delete mode. Select an expense entry from the grid to delete. To return to normal mode, select the Delete button again.
On tablet or desktop, the Delete button will delete the expense entry displayed on the left panel.
Filter (filter)
Narrow down the expenses displayed on the grid.
More icon (more)
Select the More button to open additional action buttons. To return to previous action options, select the More button again
Select AllSelect All (select all or deselect all)
Select or Deselect all the expense entries. This is only available if you select the More button. You can also use the individual check boxes in the grid or select a row to select an expense item.
QuickFill icon (quick-fill)
Select to access the Quick Fill Page and determine which expense types you want to add to expense reports.
Copy (copy)
Copy one or more expense entries. See Copy Expense Page
Delete (delete)
Select to delete one or multiple expense entries at the same time. See Deleting Expense Lines using PeopleSoft Fluid
Exception Comments (exceptions comments)
Select to display exception comments including Non-Preferred Merchant comments. Only the expense lines with exceptions are displayed. You can drill into each transaction to provide comments for the exceptions.
This icon is only displayed when the expense entry has exception comments. A bubble count indicates how many exceptions exist.
Errors Exist (error)
Displays this icon if errors exist on the expense line. To see the detail of the error, go to the Expense Entry page.
Attach (attach)
Displays this icon if an attachment has been added to the expense line.
Review and Submit
Select the Review and Submit button to review your expense report in the Expense Summary page. If the expense report has been submitted, the button will be displayed as View Summary.
Expense Entry Page
Use the Expense Entry page (EX_SHEET_LN_FL) to enter expense information.
Navigation:
From the Expense Details page, select the Add action button to add a new expense entry.
This example illustrates the fields and controls on the Expense Entry for Automobile Mileage expense type.
Expense Entry page
This example illustrates the fields and controls on the Expense Entry page for Courier Service expense type.
Expense Entry page
On a tablet or a desktop, the Expense Details and Expense Entry pages are combined and displayed on the same page.
You can view or update user defaults by selecting User Defaults from the Action menu in the Expense Entry header. The User Defaults option is available only on devices such as desktops and laptops. For more information, see Maintaining User Defaults
If an employee is GST Applicable as per the set up in their employee profile, they can manually enter the GST information on an expense report.
Some fields on this page change based on the expense type selected. For details on fields specific to an expense type, see Understanding Expense Reports by Expense Type.
Review Duplicate Lines
Select to access the Possible Duplicates Exist Page.
Date
Displays the current date, by default. You can change the date manually or choose a date using the calendar icon.
Expense Type
Select an expense type to add an expense item. The system displays the additional fields associated with the expense type after this field is selected. For more information, see Selecting Expense Types using PeopleSoft Fluid and Understanding Expense Reports by Expense Type.
If an expense entry has been imported from My Wallet, you can change the expense type if you have configured the Business Unit to allow changes to expense types imported from a Wallet. See the section Change Expense Type from My Wallet Download in Expenses Definition - Business Unit 1 Page
If you have allowed changes to expense types imported from a wallet, you can optionally enter a reason code to indicate the reason for the change in expense type. The option to set the requirement of a reason code is configured in the Expenses Definition - Business Unit 1 Page.
Changes to the expense type after the expense entry was imported from a wallet is tracked and stored in PeopleSoft tables (EX_CHNG_VALUE).
Description
Enter a description about the expense transaction.
Payment Details
Select a payment method. If the payment is made using a card, enter the card details. If you submit expenses in foreign currency, the system automatically display the currency exchange rate and converts the currency to the employee’s base currency. You can override the system-supplied exchange rate. Use the Reset Exchange Rate icon to change the overridden exchange rate to the system-defined exchange rate.
Note: If an employee is India GST Applicable as per the set up in their employee profile, and the GST Applicable value in the Employee Profile is ‘Yes’, the amount is automatically calculated and displayed based on the amounts entered in the India GST Information page. A Tax Exempt switch is available to indicate your preference if the expense must be exempted from GST or not.
Merchant
This field displays only if Merchant is selected as required fields for the expense type selected. See Setting Up Expense Types
If a non-preferred merchant is selected, you must provide a justification for not using the company’s selected preferred merchant.
Enter the non-preferred merchant that you used for this expense type. This field is free-form text.
Non-Preferred Justification
Select an option that describes why you used a non-preferred merchant. If the list of justifications don’t apply, the select Other (please specify).
  • A user-defined non-preferred justification.
    User-defined Non-preferred justifications are set up using the Non-Preferred Merchant Justifications Page.
  • Other (please specify) When selected, the system displays the Other field where you can enter free-form text. Enter a reason for using the non-preferred merchant if none of the options for the Non-Preferred Justification field were appropriate.
AttachAttach
Upload existing file or capture a receipt image for your expense report.
For more information, see Attachments Page (Expense Header Desktop).
Attendees iconAttendees
If Attendees Edit is activated for the expense type, you can then select the Attendees button. Use the Attendees Entry page to add, view, or modify attendees for the expense. For more information, see the section Expense Type Edit in Expense Types 1 Page
Select to enter GST information. For more information, see the India GST Information section in this document.
Note: This link is displayed only if an employee is India GST Applicable, and the GST Applicable value in the Employee Profile is ‘Yes’ .
Accounting icon Accounting
Select to access the Expense Report Distributions Page to review and update ChartField values for an expense line.
Receipt SplitReceipt Split
Split receipts that have already been split or split receipts that has never been split before. For more information see Splitting Receipts using PeopleSoft Fluid
Itemize Hotel Bill iconItemize Hotel Bill
Break down the hotel charges into individual expenses such as daily hotel bill, room services, internet, parking, laundry and others.
This field displays only if the Expense Type is setup with the Expense Type Edit of ‘Hotel’. The Itemize Hotel Bill wizard is a questionnaire page which you can use to split hotel bills into itemized expenses.
For more information, see Itemizing Hotel Bills using Hotel Wizard in PeopleSoft Fluid
Note: You cannot itemize the hotel bill again for the hotel/lodging expenses that have been itemized. When you drill down to view the individual expense entry, the Itemize Hotel Bill button will be unavailable. Use the Receipt Split button to do any additional itemization. For more information, see Splitting Receipts using PeopleSoft Fluid
Exceptions
Select the options to show exceptions for your expense report.
Exception Comments
Select to access the Exception Comment window and enter a comment about an exception found by the system. This comment is visible to your approver.
If the Comments Required option is selected on the Receipts Required Page, then you must enter a comment for the exception. Otherwise, a comment is optional.
If the Comments Required option is selected and a default comment is entered in the open field on the Receipts Required Page, the system automatically pulls the default comment into this field. You must select this field to view the default comment and then select Done to prevent an error.
Personal Expense
Select to indicate that the transaction is neither business related nor subject to employee reimbursement.
No Receipt
Select if no receipt is available to substantiate an expense item that requires a receipt. PeopleSoft Expenses compares the expense to the minimum amount that is required for a receipt. If a receipt is required, you may need to provide an explanation on the No Receipt Included page for not having a receipt.
Requiring Receipts can be defined two ways:
  • At the business unit level, using the Expenses Definition - Business Unit 1 Page
  • At the business unit, expense type, and payment method level, using the Receipts Required Page
If this feature is being used, a receipt verifier must verify a hard or soft copy of the receipt. For additional information about this feature, see Understanding Receipt Options for Expense Reports.
This field is controlled at business unit level. If the Enforce Receipts option is selected, the system automatically controls this option on the expense report:
  • If you add an attachment to the expense report, it is No.
  • If you don't add an attachment it is Yes.
No Receipt Reason
Select a Reason Code if a receipt is required but not attached.
Save
Select to have the system validate the entry. If there are errors, the system displays a red flag and the details of the error is displayed at the top of the page. You must correct all errors to submit.
For more information on handling errors, see Correcting Expense Report Errors Using PeopleSoft Fluid.
Cancel
Select the Cancel button to exit the Expense Entry page. Select Delete to delete the expense entry.
Review and Submit
Select to have the system perform the same checks as saving. In addition, if the report passes all system verifications, the report is sent to the approver.
Use the India GST Information page (EX_GST_LINE_SCF) to enter India GST information on an expense report.
This page is available only if an employee is India GST Applicable, and the GST Applicable value in the Employee Profile is ‘Yes’.
Expense Type
Displays the expense type selected for the expense.
Tax Category Code
Displays the tax category code based on the expense type.
Amount
Displays the total amount including the amount you spent and any GST amount.
Amount will not be displayed until all cost related fields are populated.
Physical Nature
Indicates whether an expense type is a good or a service.
Organization Name
Displays the organization name as set up in the Employee Profile
Organization State
Displays the name of the state in India as set up in the Employee Profile
GSTIN Number
Displays the GSTIN number as in the Employee Profile.
Expense Location
Displays the city, country, or geographical area where the expenses generally incurred.
Expense Location State
Displays the name of the state based on the Expense location.
Ship-To/Bill-To Location
Select a Ship-To/Bill-To Location for the goods or services.
Displays the state of the Ship-To/Bill-To Location.
Merchant
Select if the merchant is a Preferred or Non-Preferred Merchant.
Enter or select a merchant name based on your selection for Preferred or Non-Preferred Merchant.
Enter a justification.
Merchant GSTIN
Displays the Merchant GSTIN as set up in the Preferred Merchant Setup page.
Merchant Location
Select the Merchant location.
Merchant Location State
Displays the state of the Merchant location.
Receipt Number
Enter a receipt number for the expense.
SAC/HSN Code
Displays the default SAC or HSN Code as configured in the Expense Type Setup. You can override the default code.
Tax Authority
Displays the Tax Authority based on the tax category, ship-to location and merchant location. The values for the tax authority comes from the Global Setup pages.
Tax Jurisdiction
Displays the jurisdiction of the tax authority. This field is populated based on the tax authority.
Tax Code
Displays the Tax Code based on the tax category, ship-to location and merchant location.
The tax code and the applicable tax components are set up and configured in the Tax Calculation Code page.
For more information, see PeopleSoft Global Options and Reports: Tax Calculation Code Page
Cost of Good(s) or Service(s)
Enter an amount on the receipt that you incurred on the goods or services.
Calculated CGST Tax Amount
Displays the calculated Central GST tax amount for the expense line.
Override CGST Tax Amount
Enter an amount to override the Central GST tax amount.
Calculated SGST Tax Amount
Displays the calculated State GST tax amount for the expense line.
Override SGST Tax Amount
Enter an amount to override the State GST tax amount.
Tax Rate
Displays the calculated tax rate.
Transaction Amount
Displays the expense amount.
Use the Look up Expense Type prompt to select from the list of expense types. You can choose an expense type from the Frequently Used tab or from the All Types tab.
This example illustrates the fields and controls on the Expense Type Search - Frequently Used page.
Expense Type Search page
This example illustrates the fields and controls on the Expense Type Search - All Types page.
Expense Type Search - All Types (SFF)
Select Frequently Used tab to select from a list of top 10 frequently used expense types in the last six months. Select All Types to list all the expense types.
Fluid Expenses defaults to display the Frequently Used tab. If no expense types are listed, the All Types tab is the default.
After you select an expense type, the system automatically modifies the Expense Entry page and displays any additional fields required for the selected expense type.
All Types tab
There are two display options on the All Types tab.
  • Expense Category lists the expense types by expense category.
    Expense Category display option is available only if you select the Use Expense Type Category check box on the Installation Options page for Expenses. If there is no expense category setup for the employee’s business unit, the expense category option is hidden.
  • Expense Type lists the expense type alphabetically.
    Use the Search Expense Type field to search for or reduce the list by entering the description of the expense type.
VAT Fields
The VAT fields appear only if you enable the Record Foreign VAT option on the VAT Options page or if the employee's business unit is associated with a VAT entity.
Calculated VAT(calculated value-added tax)
Displays the calculated VAT unless the option has been set to hide for your organization.
No VAT Receipt(no value-added tax receipt)
Select if the employee did not submit a receipt for a VAT expense item that requires a receipt. You can set up approval and audit rules so that expenses with VAT but without receipts require approval and auditing because in many countries you cannot claim tax credits for the VAT without a receipt. When you select this option, PeopleSoft Expenses sets the recovery percentage and rebate amount fields to zero.
Override VAT (override value-added tax)
Enter an amount to override the calculated VAT.
See Setting Up VAT Driver Defaults for PeopleSoft Expenses and Entering VAT Information on Expense Reports.
There are multiple ways to delete expense lines.
To delete a single expense entry:
  1. Select the specific line.
  2. Select the Delete button at the end of the page.
To delete multiple expense entries:
  1. Select the More button.
  2. Select the expense entries you want to delete.
    You can use the Select All button if you want to delete all the expense entries.
  3. Select the Delete button at the beginning of the page.
This example illustrates the fields and controls on the Expense Entry Page - Delete Expense Lines.
Deleting Expense Lines (SFF)
If you import enhanced data (Hotel/Lodging expense type) from credit card vendors, and you delete a transaction detail line, then all of the detail transaction lines that were imported are deleted for the transaction. You cannot delete individual detail lines that are enhanced data. If you delete an enhanced data detail line, a message is issued that all lines associated with the Hotel/Lodging expense type will be deleted.
If the expense line was imported from My Wallet, the data will be returned to My Wallet page. If the expense line contain attachment was uploaded from My Receipts page, the file will be returned to My Receipts page.
Use the Expense Report Summary page (EX_SHEET_SUM_FL) to view the total summary of the expense report and allow user to submit the expense report.
Navigation:
Expense Details page, and then Review and Submit (For Expense Report in Pending status).
Expense Details page, and then View Summary (For Expense Report that has been submitted).
This example illustrates the fields and controls on the Expense Report Summary page as displayed on a smartphone. You can find definitions for the fields and controls later on this page.
The Export Report Summary section of the Expense Summary page provides the total summary of the expense report. If there are errors in the expense entry, a high level error message displays at the top of the Expense Summary page. You will need to return to the Expense Details page to correct the error. An expense report will not be submitted if there is error.
View General Information
Select to view or update the General Information page of an expense report.
View Printable Report
Select to view a printable expense report in PDF format. When the printable report opens, you can either select to print or download the report.
Note: The printable expense report displays India GST amounts if the Enable India Goods and Service Tax check box is selected on the Application Fundamentals: Installation Options - Overall Page.
Update Details / View Details button
Select to access the Expense Details PageExpense Details page.
The Update Details button displays if the expense report has not been submitted. The View Details button displays if the expense report has been submitted.
Submit button
The Submit button displays if there are no errors on the expense entry.
Select to submit your expense report for approval. After you submit the expense report, you cannot modify it. You can only view expense reports after you have submitted them.
To complete your expense report submission, select Submit on the Submission Confirmation pop up message.
Note: The certification message can be updated in the Message Catalogue.
After the expense report is submitted, you are transferred to the My Expense Reports Page.
Withdraw button
The Withdraw button displays if the expense report is submitted and it is pending approval. As long as your expense report is not approved, you can withdraw submission of your expense report.
There will be time when the system takes longer to complete the withdraw process. You will need to wait for a few second and select the Refresh Approval Status button. This will refresh the page and will allow you to modify the page.
This example illustrates the fields and controls on the Expense Summary page as displayed on a tablet. You can find definitions for the fields and controls later on this page.
Expense Summary
You can view or update user defaults by selecting User Defaults from the Action menu in the Expense Summary header. The User Defaults option is available only on devices such as desktops and laptops. For more information, see Maintaining User Defaults
Expense Report Summary Section
Only non-zero amount total are displayed in the Expense Report Summary section. The complete list of possible total summary are given below:
  • Total expenses
  • Employee Credit amount
  • Non-reimburse amount
  • Prepaid Expenses amount
  • Advance Applied
  • Due to Company
  • Due to Employee
  • Due to Supplier
Additional Information Section
The Additional Information section of the Export Summary page has these options:
Cash Advance
Displays the Cash Advance section if the employee has an outstanding cash advance or an cash advance adjustment. When you drill into the cash advance section, the Apply Cash Advance Page.
Note: The Cash Advance section does not display if a cash advance does not exist for the employee.
Reason for not applying cash advances
Select to access the Reason for Not Applying Cash Advances window where employees can enter a justification for not applying an outstanding cash advance.
For additional information about this feature, see Setting Up Cash Advance Enforcement.
Travel Authorization
Displays the Travel Authorization section if:
  • A Travel Authorization has already been linked to the expense report
  • Approved Travel Authorizations that can be linked to the expense report
  • The expense report has been created by copying the Travel Authorization data. For more information on copying a travel authorization, see Travel Authorization Search Page
For information on Associating a Travel Authorization to an expense report, see Associating Travel Authorizations to Expense Reports in PeopleSoft Fluid
Note: Travel Authorization section is not displayed if there is no data that can be applied to the expense report.
View Analytics IconView Analytics
Select to access a page to view expenses by type, by department, and project and activity. For more information, see Viewing Analytics in PeopleSoft Fluid.
Notes IconNotes
Select to access the Notes page for this expense report. Use the Notes page to add notes or view notes from other users.
Use the Edit button to edit your notes. You can delete your notes only if the expense report status is in Pending or Open status. Existing notes, or notes entered as part of the approval process cannot be deleted. For more information, see Working with Notes and Notifications Using PeopleSoft Fluid
Approval Status Section
The Approval Status section of the Expense Summary page displays the Approval History, Approval path and the action taken.
If there are multiple approvers or a Pooled approver, you can select the (Pooled) hyperlink to view the list of the approvers.
