Case Recognition Scenario
| Sequence | Procedure | Benefits Provider | Person | Comment |
1 |
A2341 |
Dr Jackson (OON) |
John Doe |
Ancillary to case ABC |
2 |
B6687 |
Dr Smith (IN) |
John Doe |
Not case related |
3 |
C9348 |
Dr Smith (IN) |
John Doe |
Primary case ABC |
4 |
D3921 |
Dr Jackson (OON) |
John Doe |
Dr Jackson is not in a product provider group. Dr Smith is.
Person John Doe is subscribed to the BASE product on all service dates in the claim.
Product Benefit Specifications
| Product | Code | Proc Grp contains | Product Netw | Case Def | Regime |
BASE |
B1 |
A2341 and D3921 |
IN |
ABC |
Covered in Full |
BASE |
B2 |
A2341 and D3921 |
OON |
ABC |
Coinsurance 20 |
BASE |
B3 |
A2341 |
IN |
Copay 20 |
BASE |
B4 |
B6687 |
IN |
Covered in Full |
BASE |
B5 |
B6687 |
OON |
Copay 20 |
BASE |
B6 |
C9348 |
EITHER |
ABC |
Covered in Full |
Case Definition
Recognition rules for ABC. If the primary line is IN, then out of network ancillary lines treated as IN as well.
| Type | Proc Grp contains |
Primary |
C9348 |
Ancillary |
A2341 and D3921 |
Benefit Selection Phase 1
The lines are processed in sequence 1,2,3,4.
Line 1: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B1, B2 and B3. Because this set contains at least one specification with a case definition (two to be exact, B1 and B2) OHI Claims continues to evaluate if line 1 qualifies as a primary line.
Before checking if line 1 qualifies as a primary line, it needs to be made sure that line 1 does not also qualify as an ancillary line to an already existing case, as this takes precedence. First, it is checked if line 1 can be attached to an existing case ABC; which it can not. Second, it is checked if line 1 is recognized as primary; again, it does not. Line 1 is marked as possible ancillary. B1, B2 and B3 are marked as possible candidates for line 1.
Line 2: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B4 and B5. Neither benefit specification refers to a case definition, so line 2 continues with the evaluation of the product provider group status. The result is that B4 remains as the only candidate for line 2.
Line 3: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B6. Since B6 refers to a case definition, so OHI Claims continues by evaluating if line 3 is a primary line.
Before checking if line 3 qualifies as a primary line, it needs to be made sure that line 3 does not also qualify as an ancillary line to an already existing case (since this takes precedence). First, it is checked if line 3 can be attached to an existing case ABC; which it can not. OHI Claims then checks to see if line 3 qualifies as primary; which it does. Line 3 creates a new case. B6 is marked as the only possible candidate for line 3.
Line 4: the selection on procedures, diagnosis, person age, person gender and dynamic conditions leaves only B1 and B2. Because this set contains at least one specification with a case definition (in fact both specifications) OHI Claims continues to evaluate if line 4 qualifies as a primary line.
Before checking if line 4 qualifies as a primary line, it needs to be made sure that line 4 does not also qualify as an ancillary line to an already existing case (since this takes precedence). First, it is checked if line 4 can be attached to an existing case ABC; which it can. Because this takes precedence, it’s no longer necessary to check if line 4 would start a case. Line 4 is marked as possible ancillary. B1 and B2 are marked as possible candidates for line 4.
On overview of the results after phase 1:
| Claim | Results | ||||
Sequence |
Procedure |
Benefits Provider |
Person |
Possible Ancillary? |
Ben Specs |
1 |
A2341 |
Dr Jackson (OON) |
John Doe |
Yes |
B1, B2 and B3 |
2 |
B6687 |
Dr Smith (IN) |
John Doe |
No |
B4 |
3 |
C9348 |
Dr Smith (IN) |
John Doe |
No |
B6 |
4 |
D3921 |
Dr Jackson (OON) |
John Doe |
Yes |
B1 and B2 |
Benefit Selection Phase 2
Phase two only processes lines that are possible ancillaries to an existing case. This means line 1 and 4.
Line 1: Line 1 starts with the selection from phase 1, i.e., B1, B2 and B3. First, OHI Claims attempts to attach line 1 to an existing case. The case created by line 3 in phase 1 is found and line 1 qualifies as an ancillary line to that case.
The next step is that the remaining benefit specification is filtered in context of case definitions: because B3 does not specify a case definition, it is eliminated.
The last filter is in the context of the provider group status. Because line 1 is part of a case of definition ABC, it is treated as IN given that the primary line (line 3) is IN. Therefore benefit specification B2 is eliminated. Only B1 remains.
Line 4: Line 4 starts with the selection from phase 1, i.e., B1 and B2. First, OHI Claims attempts to attach line 4 to an existing case. The case (of definition ABC) created by line 3 in phase 1 is found and line 4 qualifies as an ancillary line to that case.
The next step is that the remaining benefit specification is filtered in context of case definitions: both B1 and B2 specify case definition ABC, neither is eliminated.
On overview of the results after phase 2:
Sequence |
Procedure |
Benefits Provider |
Person |
Ben Specs |
1 |
A2341 |
Dr Jackson (OON) |
John Doe |
B1 |
2 |
B6687 |
Dr Smith (IN) |
John Doe |
B4 |
3 |
C9348 |
Dr Smith (IN) |
John Doe |
B6 |
4 |
D3921 |
Dr Jackson (OON) |
John Doe |
B1 |
After phase 2, the evaluation of the regimes can start.
