Clean Up Pricing Results
If the claim line has been processed before, the old results may need to be discarded before a new calculation takes place.
Claim lines that are processed a second time still have (old) calculation results attached. This step cleans up the results of claim lines that are to be recalculated. The Locked indicator, Keep Pricing indicator, Keep Benefits indicator, the Skip Tag for Allowed and fatal messages of specific origins allows for specific lines to be excluded from (re)calculation.
The clean up pricing results flow is schematically depicted by the following figure.
The first step is to check per line whether that line’s pricing results remain untouched or whether they are going to be recalculated.
Lines That Are Not (Re)Calculated
Fatal Messages
Claim lines with a product independent fatal message of origin MANUAL, EXTERNAL, SANITY CHECKS, PRE PRICING, ENROLLMENT or RESERVATION (attached to the line itself, the bill or claim to which the line belongs) are not going to be recalculated. The pricing results on the claim lines are kept.
Locked, Keep Pricing, Keep Benefits or Skip Tag for Allowed
Claim lines with a checked Locked indicator, checked Keep Pricing indicator, checked Keep Benefits indicator and/or a Skip Tag for Allowed are not going to be recalculated. The pricing results on the claim lines are kept.
Lines That Are (Re)Calculated
The results from an earlier pricing calculation are removed:
Claim, bill and claim line pricing messages (i.e. messages with origin PRICING, PRICING LIMIT or PRICING NO RECALCULATION)
Note that claim and bill messages are only removed if at least one non-replaced and non-locked claim line has unchecked 'Keep Pricing' and 'Keep Benefits' indicators
The allowed amount (including the currency) of the claim line is cleared (set to null)
The allowed number of units of the claim line is cleared (set to null)
The claim line provider pricing clauses are removed
The indicator "Manual Pricing" on the claim line is unchecked
The preliminary provider limit consumption is removed*
* It is possible that preliminary consumption exists if the claim has been rerouted from the status MANUAL PRICING ADJUDICATION, MANUAL BENEFITS or MANUAL ADJUDICATION to the status CHANGE or MANUAL PRICING. Note that when a preliminary provider limit consumption is deleted, the counter period is also removed if no consumption remains under that period and the counter is also removed if no consumptions exist at all under that counter.
* Preliminary consumption for a quote claim that is unfinalized and being re-processed
