Adjustment and Surcharge Rule Data Model
The adjustment rule and the surcharge rule are both referred to as an Adjustment Rule at the entity level. The adjustment value and surcharge value both point to the Adjustment Value.
Adjustment Rules
The adjustment rules are configured within the default time period by defining dimension values and default adjustment values for the scheduledefinition. The adjustment rule couples an adjustment value to the combination of the values of the schedule dimensions (one or more dimension as defined by schedule definition). It points to the adjustment value on one side and the applicable schedule dimension values on the other side. A unique adjustment rule is added for the combination of the values of the schedule dimensions, pointing to an adjustment value.
Model Adjustment Rules
The adjustment rule has the following attributes:
Field Description
Schedule Definition
Points to the schedule definition of type 'Adjustment' or 'Surcharge'
Default Time period
The default time period to which the adjustment rule belongs
Default Adjustment Value
A default adjustment value has the following attributes:
Field Description
Adjustment Rule
The reference to the adjustment rule. Unique in combination with the default time period.
Amount
The amount by which the premium is lowered or increased
Currency
The currency of the adjustment amount
Percentage
The percentage by which the premium is lowered or is increased
Function
Dynamic logic function to calculate the adjustment amount
Default Time Period
The default time period to which the adjustment value belongs
Schedule Dimension Value
A schedule dimension value stores the value of the configured schedule dimensions. It has the following fields:
Field Description
Schedule Dimension
The schedule dimension to which the value belongs to
Value From
The schedule dimension value from (if the dimension is of type Value, then this will store the exact value)
Value From Currency
The currency of the dimension from amount
Value To
The schedule dimension value to (this only applies to schedule dimensions with usage Range)
Value To Currency
The currency of the dimension to amount
Premium Schedule Line
The reference to a premium schedule line
Add-on Premium Schedule Line
The reference to an add-on premium schedule line
Adjustment Rule
The reference to an adjustment rule
Fee Schedule Line
The reference to a fee schedule line
Constraints
  • Exactly one of premium schedule line, add-on premium schedule line, adjustment rule or fee schedule line must be specified
