Premium Tiers
A premium tier is a re-usable look-up table for policy enrollment structures or "risk profiles" to support premium calculation per policy rather than premium calculation per member.
A premium tier has the following fields:
Field | Description |
Code |
The code of the premium tier |
Display Name |
The display name of the premium tier |
Equation Type |
Specifies the number of enrollments comparison. Possible values are:
Number of Enrollments |
The total number of enrolled persons or objects on a policy in relation to the equation type |
A premium tier only specifies the total number of enrolled persons or objects on a policy. A tier can be specified in more detail by setting up 'premium tier types' that specify which enrollments types must (not) be part of the tier:
Enrollment Type |
Reference to an enrollment type |
Equation Type |
Number of Types |
The total number of enrolled persons or objects of an enrollment type on a policy in relation to the equation type |
