Siebel Object Interfaces Reference > Mobile Web Client Automation Server Quick Reference >
Business Component Methods for Mobile Web Client Automation Server
Table 32 lists a summary of the Business Component methods' syntax.
Table 32. Business Component Methods Syntax Summary
Method
Description
Syntax
ActivateField Method
Allows queries to retrieve data for the specified field.
Dim busComp as SiebelBusComp
Dim bool as Boolean
bool = BusComp.ActivateField(fieldName as String)
ActivateMultipleFields Method
Allows queries to retrieve data for the fields specified in the property set.
Dim buscomp as SiebelBusComp
buscomp.ActivateMultipleFields(oPropSet as SiebelPropertySet)
Associate Method
Creates a new many-to-many relationship for the parent object through an association business component.
Dim bool as Boolean
bool = busComp.Associate(whereIndicator as Integer)
BusObject Method
Returns the business object that contains the business component.
Dim busObject as SiebelBusObject
Set BusObject = busComp.BusObject
ClearToQuery Method
Clears the current query and sort specifications on the business component.
Dim bool as Boolean
bool = busComp.ClearToQuery
DeactivateFields Method
Deactivates every currently activated field.
Dim bool as Boolean
bool = busComp.DeactivateFields
DeleteRecord Method
Removes the current record from the business component.
Dim bool as Boolean
bool = busComp.DeleteRecord
ExecuteQuery Method
Retrieves a set of BusComp records.
Dim bool as Boolean
bool = busComp.ExecuteQuery(cursorMode as Integer)
ExecuteQuery2 Method
Dim bool as Boolean
bool = busComp.ExecuteQuery2(cursorMode as Integer, ignoreMaxCursorSize as Boolean)
FirstRecord Method
Moves to the first record in the business component.
Dim bIsRecord as Boolean
bIsRecord = busComp.FirstRecord
GetAssocBusComp Method
Returns the association business component.
Dim AssocBusComp as SiebelBusComp
Set AssocBusComp = busComp.GetAssocBusComp
GetFieldValue Method
Returns a value for the field specified in the argument.
Dim sValue as String
sValue = busComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method
Returns a formatted value for the field specified in the argument.
sValue = busComp.GetFormattedFieldValue(FieldName as String)
GetLastErrCode Method
Returns the last Siebel error number.
Dim iErr as Integer
iErr = buscomp.GetLastErrCode
GetLastErrText Method
Returns the last error text message.
Dim sErr as String
sErr = busComp.GetLastErrText
GetMultipleFieldValues Method
Returns a value for the fields specified in the property set.
buscomp.GetMultipleFieldValues(oPropSet as SiebelPropertySet, PValues as SiebelPropertySet)
GetMVGBusComp Method
Returns the MVG business component associated with the field specified in the argument.
Dim mVGBusComp as SiebelBusComp
set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method
Returns the argument-named search specification.
sValue = busComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method
Returns the pick business component associated with the field specified in the argument.
Dim pickBusComp as SiebelBusComp
Set pickBusComp = busComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method
Returns the current search expression.
Dim sExpr as String
sExpr = busComp.GetSearchExpr
GetSearchSpec Method
Returns the current search specification for the field specified in the argument.
Dim sSpec as String
sSpec = busComp.GetSearchSpec(FieldName as String)
GetUserProperty Method
Returns the value for the property name specified in the argument.
sValue = busComp.GetUserProperty(propertyName as String)
GetViewMode Method
Returns the visibility mode for the business component.
Dim iMode as Integer
iMode = busComp.GetViewMode
InvokeMethod Method
Calls the specialized method named in the argument.
Dim sReturn as String
sReturn = busComp.InvokeMethod( methodName as String, methodArgs as String or StringArray)
LastRecord Method
Moves to the last record in the business component.
Dim bReturn as Boolean
bReturn = busComp.LastRecord
Name Method
Returns the name of the business component.
Dim sName as String
sName = busComp.Name
NewRecord Method
Adds a new record to the business component.
Dim bool as Boolean
bool = busComp.NewRecord(whereIndicator as Integer)
NextRecord Method
Moves to the next record in the business component.
bReturn = busComp.NextRecord
ParentBusComp Method
Returns the parent business component.
Dim parentBusComp as SiebelBusComp
Set parentBusComp = busComp.ParentBusComp
Pick Method
Places the currently selected record in a picklist business component into the appropriate fields of the parent business component.
busComp.Pick
PreviousRecord Method
Moves to the previous record in the business component.
bReturn = busComp.PreviousRecord
RefineQuery Method
Refines a query after a query has been executed.
busComp.RefineQuery
SetFieldValue Method
Assigns a new value to the named field for the current row of the business component.
busComp.SetFieldValue(FieldName as String, FieldValue as String)
SetFormattedFieldValue Method
Accepts the field value in the current local format and assigns the new value to the named field for the current row of the business component.
busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
SetMultipleFieldValues Method
Assigns a new value to the fields specified in the property set for the current row of the business component.
buscomp.SetMultipleFieldValues(oPropSet as SiebelPropertySet)
SetNamedSearch Method
Sets a named search specification on the business component.
busComp.SetNamedSearch(searchName as String, searchSpec as String)
SetSearchExpr Method
Sets the search expression for the business component.
busComp.SetSearchExpr(searchSpec as String)
SetSearchSpec Method
Sets the search specification for the specified field.
busComp.SetSearchSpec(FieldName as String, searchSpec as String)
SetSortSpec Method
Sets the sort specification for a query.
busComp.SetSortSpec(sortSpec as String)
SetUserProperty Method
Sets the value of the specified User Property.
busComp.SetUserProperty(propertyName as String, newValue as String)
SetViewMode Method
Sets the visibility type for the business component.
buscomp.SetViewMode(mode As Integer)
UndoRecord Method
Reverses any uncommitted changes made to the record.
busComp.UndoRecord
WriteRecord Method
Commits to the database any changes made to the current record.
busComp.WriteRecord
