Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
Rackmount Kit (Part number 350-1662-02)
This rackmount kit includes the multi-piece CMA. If your rackmount kit includes the CMA comb, see Rackmount Kit (Part number 7069640).
The rackmount kit has two shelf rails, one for each side of the rack. Each shelf rail is marked LEFT or RIGHT.
The shelf rails are mounted to the rack or rack with four adaptor brackets. The shelf rails adjust to fit rack depths from 25 to 34.25 in. (63.5 to 87 cm).
image:Illustration showing the rackmount kit.
No.
Description
1.
Upper rear brackets
2.
Shelf rails
3.
Adapter brackets (two types provided, for racks with either square mounting holes or round mounting holes)
4.
Flathead screws
5.
Cage nuts
6.
M6 screws
7.
Rackmount screws
Related Information
