If your network does not use DHCP, the
NET MGT port is not operational until you configure network settings
for the SP.
Note - If you are unable to use DHCP on your network, you must
connect to the ILOM SP using the SER MGT port to configure the NET
MGT port for your network. See Assign a Static IP Address to the NET MGT Port.
