Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
Prepare the Power Cords
Prepare the power cords by routing them from the AC power source to the server.
Caution
Caution  -  Use only the power cords provided with the server.
Caution
Caution  -  Do not attach power cables to the power supplies until you have connected the server to a serial terminal or a terminal emulator (PC or workstation). The server goes into Standby mode and the Oracle ILOM SP initializes as soon as a power cable connects a power supply to an external power source. System messages might be lost after 60 seconds if a terminal or terminal emulator is not connected to the SER MGT port before power is applied.
Note - Oracle ILOM will signal a fault if both power supplies are not cabled at the same time, since it will be a nonredundant condition. Do not be concerned with this fault in this situation.
  • Route the power cords from the AC power source to the rear of the server.
    Do not attach the power cords to the power supplies at this time.
Related Information
